Buying rims for 2002 Blazer
Old Oct 28, 2011 | 12:20 PM
brendan127's Avatar
Banned
brendan127 is an unknown quantity at this point
Default Buying rims for 2002 Blazer
I want to get a set of rims from All Terrain Tires, Steel and Alloy Wheels, Suspension Systems, and Accessories by Pro Comp USA could you guys be specific on what bolt pattern and if the backspacing matters.. I know it's 15x7 size.
EDIT: I have a 2002 Blazer ZR-2
Old Oct 28, 2011 | 04:28 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
5x4.75 for blazers, between 4"-6" back spacing would be ideal. 6" is stock so if you go 4" back spacing your tires will stick out 2" more than stock.
Old Oct 29, 2011 | 05:03 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
That's if you have a 4x4, 2wd's have less back spacing.
Old Oct 29, 2011 | 08:49 AM
gatorboy44's Avatar
What's the backspacing on 2wd? I've never owned one.
Old Oct 29, 2011 | 04:43 PM
Thogert's Avatar
4in on a 2wd.
Old Oct 29, 2011 | 06:04 PM
gatorboy44's Avatar
I wish ours was 4" then I could fit much better rims.
Old Oct 30, 2011 | 03:33 AM
Yeah, but atleast the 4wd wheels sit out closer to the corners and can run Vette or Iroc rims with no problems.
On 2wd's the wheels are sunk into the wheel well, I have to run spacers on every wheel just so they don't look so sunk in.
Before spacers.
2" spacer.
Old Oct 30, 2011 | 09:01 AM
gatorboy44's Avatar
The rear tires are sunk in 1.5" in the back compared to the front on 4wd, looks stupid. So I need to buy spacers.
Old Oct 30, 2011 | 12:31 PM
brendan127's Avatar
Banned
I want my tires stick out farther anyways, lol. So these pro comp's should work right?
Old Oct 30, 2011 | 12:53 PM
gatorboy44's Avatar
You should be alright
