Camaro wheels, spacers help!
Old Apr 6, 2021 | 08:06 PM
Obeydmaster's Avatar
Obeydmaster is on a distinguished road
Default Camaro wheels, spacers help!
Hello new to the forum I been searching online and Facebook forums and no one has been able to give me a straight answer on this matter, I scooped up a set of 18 inch steel Camaro wheels with stock tires, I am looking for adapters and do not know the right size to get does anyone know what exact size I need, I have heard 1.5 inch, 2 inch and even 2.5 inch, also some people states that i need to change from 5x4.75 to 5x120. Any help would be appreciated. New here also I did search the forum but did not get s concrete answer.
Old Apr 7, 2021 | 01:18 AM
AJBert's Avatar
What year Camaro wheels did you get? And do you have a 2wd or 4wd? That info alone will get you some answers.
Old Apr 7, 2021 | 05:21 AM
I have a 2005 2wd blazer.
Here are the specs for the Camaro wheels.
​​​​chevrolet Camaro 2010-2015
Product Specifications:
Product ID: STL5440/5527
Product: Wheel/Rim (Single)
Material: Steel
Style: 5 Spoke
Finish: Powder Coat Black
Lugs: 5
Bolt Pattern: 120mm
Option Code: Q50, RT2
Indents: F2558
OE Part Number: 92197458, 22844561
Old Apr 7, 2021 | 10:19 AM
2wd, 2005 blazer. 2010 Camaro steel wheels.
Old Apr 8, 2021 | 10:54 AM
El_Beautor's Avatar
2010 and up Camaros use a 5x120mm bolt pattern. S-series trucks like your Blazer use a 5x4.75" bolt pattern, so to do it proper you will need to have spacers that adapt the bolt pattern.
I've never done it myself, but I've read that most people who do what you're trying to do use 2" spacers on a stock suspension truck. It will depend a bit on the offset (or backspace) of your new rims, how wide they are, and what look you are trying to achieve. It will also depend on if your truck is stock or modified. Is it lowered or lifted? Are you thinking of lowering or lifting it?
BrinkDiamond
Tires and Wheels
Jul 4, 2024 09:05 AM
ZEPPLIN23
Tires and Wheels
Dec 9, 2013 03:05 PM
phrankguy1
Tires and Wheels
Aug 1, 2009 12:27 PM
Ash
Tires and Wheels
Sep 29, 2008 04:01 PM
SkylineGTSt
Tires and Wheels
Apr 11, 2007 02:39 AM
