Cragar Soft 8 16", will it fit?
Old Jul 7, 2010 | 04:36 PM
R2P's Avatar
R2P
R2P is on a distinguished road
Default Cragar Soft 8 16", will it fit?
Firstly, details: 1998 S10 Blazer LT, 4x4, 4dr
Ok I was wanting to replace my tires with Nitto Terragrapplers but they're only made to fit on a 16" rim minimum and the Blazer has a 15" rim, so I decided this would be a good time to new rims.
The cragar soft 8's I like, but I don't know all the details about what will fit.
http://www.summitracing.com/parts/CRR-3977734/
I found these and they look they should fit but the backspacing is 2" less than stock and I've read you should really need negative offset with 4x4.
Another thing, I want wider tires than the stock 235's so what's the widest that will fit without rubbing? I searched and found a lot of questions about max height, but not much about max width. I'm thinking 265 would be max.
Old Jul 7, 2010 | 04:50 PM
84BlazerS10's Avatar
That type of rim would fit your blazer just make sure you get one with the 5-4.75 bolt pattern. As far as the back spacing if you get one with 0 off set you might have to run some spacers or something there is tons of members that have these rims on their blazer that might be able to help you out more. Also, I'm not sure how wide of tire you can run without rubbing but you might check out this calculator.
http://www.1010tires.com/tiresizecalculator.asp
If you go over a 3% diameter difference you increase your chance of brake failure.
Old Jul 7, 2010 | 05:22 PM
Benedict1337's Avatar
I think you can get away with 245 or 255 but use the tire calculator, stock height I wouldn't go much taller than 235/75/15's with those rims or you will have rubbing issues unless you wanted to lift your truck
Old Jul 8, 2010 | 12:10 AM
R2P's Avatar
R2P
I did do a T-bar crank and added an inch.
I think I'll just go with Pirelli Scorpion ATR's and the 15" soft 8's. Would I have any trouble with 255/75R15? The tire calculator says its a little under 4% size increase.
Old Jul 8, 2010 | 12:29 AM
In terms of fitting I wouldn't think you should have a problem but as i mentioned the bigger you go the more you increase your risk of brake failure so that part is for you to decide.
Old Jul 9, 2010 | 05:35 AM
R2P's Avatar
R2P
Ok thanks. I'll just go with high end brake pads whenever they need replacing, possibly performance rotors too.
Cojack2
Tires and Wheels
Nov 19, 2010 07:37 AM
Jisher
Tires and Wheels
Jul 4, 2010 11:42 PM
appstateblazer
Tires and Wheels
Jan 12, 2010 10:37 PM
99Jimmster
Tires and Wheels
Aug 20, 2009 08:51 PM
