Cragar ss rims for a 95 blazer 4wd
Old Aug 7, 2008 | 10:24 AM
Kingswede's Avatar
Kingswede is an unknown quantity at this point
Default Cragar ss rims for a 95 blazer 4wd
I found a really nice deal on a set of cragar ss rims and i wanted to know if they would fit on a 95 4wd ls blazer. the measurements are as follows; Cragar: 15x7, bolt pattern-4.75", offset-3mm, backspacing 4-1/8"... i'm not too sure about the backspacing and offset on my current rims but everything else matches the cragar rims, thanks in advance for any help
Old Aug 7, 2008 | 10:30 AM
Default RE: Cragar ss rims for a 95 blazer 4wd
They will stick WAY out. Your stock rims are 6" back spacing.
Old Aug 7, 2008 | 11:07 AM
WolfPack's Avatar
I wouldnt say wayyyyyy out...you'll get a wider track, definitely though. My rims have 4.5' backspacing. I will say though, 235/75/15 stock tires look a little interesting with the wider track... Are you planning on new tires any time soon?
Old Aug 7, 2008 | 11:21 AM
~2" per side is quite a ways...
Old Aug 7, 2008 | 11:23 AM
WolfPack's Avatar
Eh...I suppose so...I think I'm just used to mine. I forget the stock blazers have the wheels tucked up under the body.
Old Aug 7, 2008 | 11:25 AM
Some states require tires to be "under the body". By pushing them out, you may be required to have fender flares to cover them back up.
Old Aug 7, 2008 | 04:31 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Wolfpack: how far do your tires stick out? wanna know how far and what it looks like. thanks
Old Aug 7, 2008 | 04:32 PM
Kingswede's Avatar
Hey guys thanks for the info, i'm planning on new tires but i definitely wouldn't want the tires to stick out 2", swartlkk- i'm also a firefighter here in NY, i'm with New Hackensack, glad to see a fellow brother
Old Aug 7, 2008 | 04:35 PM
Kingswede's Avatar
Old Aug 8, 2008 | 03:01 AM
WolfPack's Avatar
Rims are 15x8 with 4.5' backspacing, so mine go out ~1.75' wider than stock. I love the wider stance, but NC has no exposed tread law..
These pics are pre any lift. I just stuffed the 265/70s in the wells and tried to drive [:-]
It's pretty much ZR2 track width....without the flares
