Curious mind wants to know...
Old Sep 21, 2009 | 09:55 PM
Crap Blazer's Avatar
Crap Blazer is on a distinguished road
Default Curious mind wants to know...
can the wheel tire combo on the full side Cheny trucks fit on a Blazer?
Old Sep 21, 2009 | 10:02 PM
TripleBlackBlazer's Avatar
Yeah if you want to convert to 6 lug.
Old Sep 22, 2009 | 09:58 PM
What does this entail? If it is straight forward, what are the advantages and drawbacks?
Old Sep 22, 2009 | 10:34 PM
okvortec's Avatar
The drawbacks would be a more exspensive rim, and tire.
Can't really think of the advantages other than looking cool?
Old Oct 24, 2009 | 10:42 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
what bout older five lug fullsize wheels and tires?
Old Oct 25, 2009 | 07:41 AM
I believe that the older full size 2wd trucks had a 5 on 5" bolt circle. So no dice... 4WD GM trucks were 6 lug going back a LONG way. Only the 2wd trucks were 5 lug and I believe that they were 5x5 for a long time.
A lot of the older GM car rims will be 5x4.75 like the s-series trucks though. I know that the rally's from my '70 Chevelle would have bolted up to my old '00 Bravada.
Old Oct 25, 2009 | 11:50 AM
ABN31B's Avatar
anything on a 5x4.75 will bolt on. (5 lugs, 4.75 around the lugs (connect the dots))
it's back spacing that becomes an issue. if you want bolt on and go rims, your stockers have 6" of BS so you would want something as close to that as you can get it.
You can work with all of the S series like Kyle said, (blazer, jimmy, bravada, s10, s15, sonoma, etc) plus you can get away with Corvette, Camaro, Nova, Chevelle and El Camino Rims. Search around on here. There is a ton about this very thing.
you COULD get a converter plate to bolt on you your wheels (5x4.75) --> 6 x whatever, but you would be sticking them out further and putting something between your wheels and axels... so give a little (strength and safety) to get a little (new look). worse things have been done though
jimbosv650
Feb 18, 2008 01:50 PM
ripoffblazer
Jun 7, 2007 10:06 AM
juscarter
Dec 26, 2006 09:53 AM
TheDesertFox
Aug 15, 2006 01:07 AM
