differance in tire sizes??
I want to put either 33" or 35" tires on my truck. It's gonna have a 6" suspension lift with a 3" body lift.. Will there be a noticeable power loss cause they're such big tires? It's probably gonna cause excess wear on the clutch, will it be a lot of wear with these tires? And i want them to be 12.5" wide will i have to put wheel spacers/ different rims so when i turn the steering wheel it wont hit the frame??
33's will be fine, you will need to put new gears in such as 4:56 or so to make up for the larger diameter tire. I have heard that 35s may be too big for the blazers IFS to hold up to, maybe someone else will chime in and know for sure. Hope this helps,
Jon
Jon
You will not lose any power... it will just require more power to turn the wheels.
As stated lower gears (higher numbers) will be needed otherwise it will feel very sluggish.
The wear will just be increased. I have seen companies make IFS parts that hold up to a lot more, but can not think of them off the top of my head. One company was featured in a 4x4 magazine and they were from Northern Illinois and basically designed cv joints that could withstand more than traditional U joints...
I am assuming you are talking about your 87 with the 2.8 since thats the only manual listed in your sig... I would definitely stick to the 33's and re gear your truck from in the 3.00's to up in the high 4's... 4.56 is very popular as stated earlier, but there is also 4.10 and some people have gears in the 5's but you will lose much of the Economy with the gear change.
rogggg1020
Sep 26, 2008 06:53 PM
chevblazer02
Headers, Intake, & Exhaust
Dec 27, 2006 03:44 PM
