First gen wheels?
Old Mar 5, 2010 | 09:34 PM
84BlazerS10's Avatar
Default First gen wheels?
would a pair of IROC Camaro rims 16x8 directly bolt up to my blazer?
Old Mar 5, 2010 | 10:08 PM
AJBert's Avatar
Yes, same bolt pattern but the backspacing may not be user friendly. Would help to know what you are driving first.
Old Mar 6, 2010 | 08:15 AM
neo71665's Avatar
Front Iroc rims are the same and the factory rims if I recall. The rears are wider. My biddy has a set on his 93 excab and been running them fine for years. He just complains about the cost of 16 inch tires.
Old Mar 6, 2010 | 08:27 AM
Hanr3's Avatar
yea, 16" tires cost more than 15" tires, especially in 33".
Old Mar 6, 2010 | 11:05 AM
Thanks for the replies, It's a 1984 Blazer S10 2 door 2 wheel drive.
also would anyone know if P245/50-R16 tires would fit on them or what size could I run without rubbing problems?
Old Mar 6, 2010 | 05:38 PM
AJBert's Avatar
What size tire are you currently running? If you have 235's I would suggest something along the line of 255/60/R16 or 255/65/R16. Either of these will be very close to the same diameter of 235/75 or 70/R15. I "believe" the backspacing of the IROC rims are the same or very close to your stock rims so I don't think you'll have much, if any, of a rubbing problem.
Old Mar 6, 2010 | 08:01 PM
Well when I bought the car it came with P205/75/R15's but they are way to small
Old Mar 7, 2010 | 06:44 AM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
Front and rears are both 8" wide. Rears have more backspacing so they'll sit in farther than the front on an S truck. 245/50/16's will be fine. 1st gens had smaller tires stock (same as truck size) than 2nd gen 2wd Blazers. I have a set for my 2nd gen Blazer but found I need one rear as the lip has a chunk missing.
Old Mar 7, 2010 | 09:53 AM
thanks for the information, I was wondering about that because I was reading somewhere else that a guy was running 245's and had rubbing issues but he is also running drop spindles which I don't have.
Old Mar 7, 2010 | 11:02 AM
Zeeke98's Avatar
You only rub at full lock when you're dropped anyways. It's only a minor problem when making sharp turns in a parking lot. I've had numerous dropped vehicles and it's never bothered me. Trying to get money to drop my Blazer now.
