FIX-A-FLAT
Old Dec 16, 2007 | 08:32 PM
willjones's Avatar
Default FIX-A-FLAT
I have a very slow leak in my front drivers side tire. I can't find a leak, but I was thinking of using that FIX-A-FLAT stuff. Has anyone ever used it. Is is ok to use or is it only going to prolong the problem?
Old Dec 16, 2007 | 09:01 PM
rriddle3's Avatar
Default RE: FIX-A-FLAT
Well, it will usually seal the leak, depending on what type it is, but remember it's called 'fix-a-flat', not 'fix-a-tire'. Also, tire changers seem to hate it, saying it can cause pneumatic explosions when you dismount a tire.
Old Dec 16, 2007 | 09:02 PM
I would not recommend it. Try to find the problem with some soap and water mixed up and sprayed over the entire outside of the tire. Pay particularly close attention to where the tire meets the rim and the valve stem itself.
Fix-a-flat can end up causing an imbalance in the tire.
Old Dec 17, 2007 | 08:15 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
i dont like pix-a-flat, i have always been told it can cause more lil leaks around the rim, i like using slime, but i have never used it in a auto tire, i have it in all my 4-wheeler tires and it works great, but i could see how it could cause it to get out of balance like stated above, but it will definately seal it
Old Dec 21, 2007 | 04:33 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
fix-a-flat = Great product..... for very very very temporary use.... dont use fix-a-flat unless the tire is flat and you absolutely have to have it to get home....... i have used it on trucks, cars, and trailers... not in any permanent situations though...
Old Dec 22, 2007 | 04:18 AM
AJBert's Avatar
Bring your truck to your local tire shop. Most will find and fix the leak correctly for around $10.
Old Dec 23, 2007 | 05:53 PM
olenmarmcr's Avatar
olenmarmcr is an unknown quantity at this point
th echemicals will eat ur tire in the long run
Old Dec 25, 2007 | 11:42 AM
willjones's Avatar
Thanks for the insight
r_marczak_83
17
Mar 9, 2013 10:33 AM
Consten00
Feb 17, 2009 10:49 PM
Blazertrish66
Apr 29, 2008 07:54 PM
Dodge Guy
Oct 25, 2006 08:48 AM
bufferpad
Feb 26, 2005 12:15 PM
