help!!!!
Yes on all accounts.
I have camaro wheels and use them no problem.
Do you know what back spacing your new wheels are?
Those wheel adapters will not change your bolt pattern.
They do make some that can change your bolt pattern if you should ever need them.
Check out my build thread, i posted some pics of what i did on saturday.
These came from ebay.
https://blazerforum.com/forum/builds...d-59502/page4/
You guys are helping me so much thanks a lot! But still a little confused lol. I read that eBay link and from what I understand is as long as I get the camaro/Corvette spacers I can put them on and still use my wheels that are for my factory lug pattern is that right? And 1.5" will line them up with the front? I'm runnin 235/75/15 all the way around
Sorry bout that my page didn't show that my last post went thru. But I have no idea what spacing they are. Is there any way to tell? The front stick out quite a bit tho
Last edited by swartlkk; Apr 11, 2012 at 09:40 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
The bolt pattern remains the same. You can put your factory wheels back on should you ever wish to.
They do make adapters that change the pattern so you can fit a larger variety of wheels but just look for regular spacers.
They usually list the bolt pattern somewhere within the page. For example, with warthogdriver's link, it says 5 X 4 3/4 to 5 X 4 3/4 (Same bolt pattern to Same bolt pattern) 5x4.75 is the bolt pattern for our wheels so just make sure the listing has the same pattern
