help!!!!
Old Apr 10, 2012 | 08:39 PM
warthogdriver's Avatar
Yes on all accounts.
I have camaro wheels and use them no problem.
Do you know what back spacing your new wheels are?
Those wheel adapters will not change your bolt pattern.
They do make some that can change your bolt pattern if you should ever need them.
Old Apr 10, 2012 | 09:20 PM
Brian_D's Avatar
Check out my build thread, i posted some pics of what i did on saturday.
These came from ebay.
https://blazerforum.com/forum/builds...d-59502/page4/
Old Apr 10, 2012 | 10:57 PM
semajelah's Avatar
semajelah is on a distinguished road
You guys are helping me so much thanks a lot! But still a little confused lol. I read that eBay link and from what I understand is as long as I get the camaro/Corvette spacers I can put them on and still use my wheels that are for my factory lug pattern is that right? And 1.5" will line them up with the front? I'm runnin 235/75/15 all the way around
Sorry bout that my page didn't show that my last post went thru. But I have no idea what spacing they are. Is there any way to tell? The front stick out quite a bit tho
Last edited by swartlkk; Apr 11, 2012 at 09:40 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Apr 11, 2012 | 10:36 AM
mdehoogh's Avatar
The bolt pattern remains the same. You can put your factory wheels back on should you ever wish to.
They do make adapters that change the pattern so you can fit a larger variety of wheels but just look for regular spacers.
They usually list the bolt pattern somewhere within the page. For example, with warthogdriver's link, it says 5 X 4 3/4 to 5 X 4 3/4 (Same bolt pattern to Same bolt pattern) 5x4.75 is the bolt pattern for our wheels so just make sure the listing has the same pattern
Old Apr 11, 2012 | 02:14 PM
semajelah's Avatar
Thanks a lot guys I appreciate all the help you guys gave me
Old Apr 11, 2012 | 03:26 PM
semajelah's Avatar
And 1.5" spacers will line them up right?
Old Apr 11, 2012 | 04:15 PM
Yes 1.5 is what most of us use when doing just the back...you should be fine
Old Apr 11, 2012 | 04:44 PM
semajelah's Avatar
Ok. Thanks a lot man. I appreciate all of your guys' help
Old Apr 14, 2012 | 02:16 PM
semajelah's Avatar
Ok so I got my spacers in the mail and they have no instructions. So could someone tell me how to put them on the right way?
Old Apr 14, 2012 | 04:50 PM
mine only came with torque specs....95 ftlbs and a dab of loctite is all i did.
we need some details....did you contact seller for torque info?
