help 99 blazer 4x4
i need to know what is the offset on my 99 blazer 4x4. ive been told high and ive been told it was a 0. i need some help so i dont make a mistake on the wrong rims. thank to all!
offset? you mean back spacing?
either way, under both names it's all over the forum. try the search function if you have a question. 6" |
ok i have a 4 door 99 blazer 4x4 some sites say it has a +50 offset others say 0 offset. i dont understand im guessing the 4x4 makes it a + offset.
almost all aftermarket 15x7's have 4" BS or 4.5... it's the 6" BS you need if you're a 4wd that are hard to find...
google "cragar soft 8" and try to find a pair of 15x7's that AREN'T 4" search is the answer not emailing |
Keep in mind you don't NEED a 6" backspacing though. The 4" will do just fine, they will just stick out a bit more then the stock rims. You may have some rubbing issues too if you do with a bigger tire.
I still am curious to know if we're talking about the same thing though? You mention + and 0 amounts? That doesn't sound to me like backspacing...at least I've never heard it put in terms like that before. |
1 Attachment(s)
some manufacturers use offset instead of backaspacing. It is the distance from the center of the wheel to the mounting surface. Positive offset is what the stock wheels have, an 8 inch wide wheel with 4 inch backspacing will have 0 offset. ** offset is measured in millimeters
