help 99 blazer 4x4
Old Feb 28, 2010 | 09:16 PM
jameson8767's Avatar
jameson8767 is on a distinguished road
Default help 99 blazer 4x4
i need to know what is the offset on my 99 blazer 4x4. ive been told high and ive been told it was a 0. i need some help so i dont make a mistake on the wrong rims. thank to all!
Old Feb 28, 2010 | 09:41 PM
ABN31B's Avatar
offset? you mean back spacing?
either way, under both names it's all over the forum. try the search function if you have a question.
6"
Old Feb 28, 2010 | 09:48 PM
ok i have a 4 door 99 blazer 4x4 some sites say it has a +50 offset others say 0 offset. i dont understand im guessing the 4x4 makes it a + offset.
Old Mar 1, 2010 | 06:41 AM
warthogdriver's Avatar
almost all aftermarket 15x7's have 4" BS or 4.5... it's the 6" BS you need if you're a 4wd that are hard to find...
google "cragar soft 8" and try to find a pair of 15x7's that AREN'T 4"
search is the answer not emailing
Old Mar 1, 2010 | 08:25 AM
Sisk's Avatar
Keep in mind you don't NEED a 6" backspacing though. The 4" will do just fine, they will just stick out a bit more then the stock rims. You may have some rubbing issues too if you do with a bigger tire.
I still am curious to know if we're talking about the same thing though? You mention + and 0 amounts? That doesn't sound to me like backspacing...at least I've never heard it put in terms like that before.
Old Mar 1, 2010 | 11:29 AM
Mczuk's Avatar
Mczuk is on a distinguished road
some manufacturers use offset instead of backaspacing. It is the distance from the center of the wheel to the mounting surface. Positive offset is what the stock wheels have, an 8 inch wide wheel with 4 inch backspacing will have 0 offset. ** offset is measured in millimeters
tdbone1
15
Nov 30, 2012 06:53 PM
Tinted
35
Feb 7, 2011 01:12 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
