Help on some tires.
I have a 2000 Blazer S10. I am trying to find some new tires to get casue the tread is almost completly gone. I have 15 inch rims. Any suggestions.
RE: Help on some tires.
Are you wanting to stay with the stock tire size? (most likely 235/75r15 or 235/70r15)
What are you looking for in a tire? Better offroad traction? Longer lasting? As cheap as possible? |
I was wanting more off roading tires, and i wanted to maybe stray away from the stock tires, but to me it doesnt look like i can really get any bigger without having some rub or trimming down something. Maybe a little wider would be nice.
30x9.5 is going to be your biggest/widest without rubbing or trimming.
A pretty popular favorite are the BF Goodrich All-Terrain, but I prefer the General Grabber AT2. Made by Continental, 65,000 mile warranty, pretty much identical tread design as the BFGs. These are going to give you a little more road noise than you're used to with street tires, and if that's going to be a problem I'd look at Toyo Open Country A/Ts, or maybe a Yokohoma Geolander A/T. |
Yep the tires mentioned above are pretty popular on the blazers. Also the sizing specified is correct, which a 30x9.5 inch tire is a 2" larger than stock tire, giving you about 1" of lift dependent on the inflation pressure. I have been very pleased with the 235/75R15 BFG All Terrians I have, they have about the same noise level new as my old highway tires had when they were worn. They also have a slightly higher rolling resistance which means you could experience slightly worse gas mileage, especially between switching between highway stock tires and stock sized agressive all terrian tires. I dropped about 1-2mpg depending on driving conditions.
ORIGINAL: lennyblazer I dropped about 1-2mpg depending on driving conditions. |
I also would recommend the General Grabber AT2s. I love mine, and I think that they look great and this may be biased but I think that they look better than the BFGs.
I just checked out the 30x9.5 on the BFGs, General Grabber AT2s ,and I like them alot. I am pretty torn between the two. Ya i am perpared for the gas reduction,
Thanks for everyones help |
What is the size of stock rims to the t? Backspacing and all?
The stock rims are 15" by I think 7", the back spacing is 6" on a 4x4. You should be good mounting up to a 10.5" wide tire on the stock rim. The Generals are good looking but I like the looks of the BFG AT's better. Never really driven on the Generals but I am sure they do great as well.
Make sure that if you are getting a larger than stock tire to remember that your spedometer and trip/odometer will be off by a certain percentage (i.e. if your stock speedometer says you are going 60mph you are probably doing 61-62mph). You can calculate this online by going to this tire calculator online. Also your odometer would be off by a certain percentage (i.e mine is 3% off, so every hundred miles I drive according to the trip odometer, I really went 103 miles). You can get your computer reprogrammed through many methods to account for the change in tire size (i.e. flash tune, wait4me tune, hypertech programmer, local garage/dealer). Good luck on your tire purchase and let us know if you have any other questions. |
If you are wanting to keep close to the stock tire height (about 29") so you don't have to change the computer, you might want to look at some 255/70s. A bit wider than 235s and are 29.1" tall if memory serves.
