Im getting a weird noise and bad smell.
Old Aug 14, 2011 | 10:51 PM
bking004's Avatar
bking004 is on a distinguished road
Default Im getting a weird noise and bad smell.
ok so I just replaced my brake pads and now when ever I turn left (without applying the brakes) my rear driver side tire makes a weird grinding like noise and when I got out to check it out, the tire it was coming from was really hot and smelt very bad. I cant see anything thats wrong. Has anyone ever had the same issue? maybe you could help. Thanx
Old Aug 14, 2011 | 10:56 PM
chris015's Avatar
Sounds like a caliper is seizing up. Did you lube up the pins?
Old Aug 14, 2011 | 10:57 PM
xgiovannix12's Avatar
I agree it sounds like your caliper is sticking
bking004's Avatar
I never took em out. I only replaced the pads.
Old Aug 14, 2011 | 10:58 PM
chris015's Avatar
you have to remove em to replace the pads.....
bking004's Avatar
How do I get em to stop sticking?
how did you remove the pads with out removing the caliper ?
Old Aug 14, 2011 | 10:59 PM
chris015's Avatar
everyone can do it with 3 clicks of the little red shoes. anythings possible.
Old Aug 14, 2011 | 11:02 PM
bking004's Avatar
ok lol my dumb *** took the whole caliper off to replace the pads lmao I know how to do it the right way now, should be an easy fix. Thanx guys
chris015's Avatar
So,you MUST remove the calipers to replace the pads. you know these things :
there is 2 pics that come out the get the caliper loose. buy brake lube and lube em up!
