Im getting a weird noise and bad smell.
Old Aug 14, 2011 | 11:05 PM
bking004's Avatar
bking004 is on a distinguished road
I took off the caliper mount with the caliper all in one peice, arent you supposed to leave the mount on?
Old Aug 14, 2011 | 11:08 PM
chris015's Avatar
No. when you remove the wheel,look behind the caliper. you will see 2 pins One on top,on on bottom.
look at the right of the pic. remove these 2 pins,and tap the top of the caliper to the side with a hammer until the caliper slides off.
Old Aug 14, 2011 | 11:09 PM
bking004's Avatar
ok, that must be my problem then, lol I made a stupid
-Thanx for ur help
Old Aug 15, 2011 | 08:17 AM
To replace the pads, you must remove the caliper from the caliper bracket. You cannot replace the pads without doing this. With the setup on the front of these trucks (98+ at least), the pins are also the bolts that hold the caliper to the caliper bracket. So you did remove them. One common mistake though is not lubricating them with caliper grease before putting things back together. I always try to clean the bores in the caliper bracket really well with some solvent to get all of the old, dried up grease out before lubricating the pins and putting things back together.
Here's the dual piston caliper assembly (courtesy of Compnine.com) as used on the 98+ trucks:
Attached Thumbnails Im getting a weird noise and bad smell.-970930ts04-584.gif
Old Sep 1, 2011 | 03:57 PM
bking004's Avatar
Default Brakes locking up. 99 Blazer
ok, I've been having alot of brake problems lately. I just replaced the brake booster and both rear calipers and pads. My truck was braking fine for about a week. Now my rear driver side brakes lock up. I can't figure out whats wrong with it. No brake lines look kinked or pinched and everything else looks fine. I did have to remove the brake lines from the master cylinder so I could get to brake booster out to replace it. I don't know if I maybe messed things up there or not. Maybe one of you know what I should do or where I should look.
Blazer98guy
Nov 14, 2013 10:34 PM
okstud
Dec 2, 2011 11:48 AM
chrisblaze
May 23, 2009 02:21 PM
gERgMan
Sep 6, 2008 07:27 PM
apekim
Jun 30, 2006 04:50 PM
