Just installed Cragar Soft 8's
Old Mar 20, 2012 | 04:11 PM
azzr2's Avatar
azzr2 is on a distinguished road
Default Just installed Cragar Soft 8's
Here's info on my truck for those of you wanting to do something similar, and where i screwed up.
My 1999 Blazer ZR2 (everything is stock, including suspension)
15x8 cragar soft 8's
5 on 4.75 lug pattern
31 x 10.50 R15 MT's
After installing the new tires and wheels, I realized that the front required wheel spacers because the rims actually make contact with the brake caliper. (rims rub the caliper) I am not a fan of spacers, so my stock rims are going back on.
Stock ZR2 rims have 6" backspacing, Cragar Soft 8's I got are 4" backspacing.
They also rub the corners while turning sharp.
Old Mar 20, 2012 | 04:15 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
The rims rub on what exactly? I like that look tho
Old Mar 20, 2012 | 04:32 PM
azzr2's Avatar
OH! lol, I was typing so fast I didn't finish. The inside of the rim was actually making physical contact with the brake caliper. So the rim was actually grinding on the caliper itself. (I didn't drive it like that though) I noticed it when I mounted the rim.
Old Mar 20, 2012 | 05:27 PM
newguy's Avatar
So you should have went with 15 by 7`s?
Old Mar 20, 2012 | 05:30 PM
azzr2's Avatar
More than Likely yes, hind sight is 20/20. no big deal though. I'll work it out.
Old Mar 20, 2012 | 09:05 PM
xgiovannix12's Avatar
You can file the caliper down to clear the rims .. this has been done before
the rubbing on the sway bar and frame cant be solved with out using spacers but the caliper rub can by doing as I said above this post
up to you tho
Old Mar 20, 2012 | 09:15 PM
Brian_D's Avatar
Looks nice!
Old Mar 21, 2012 | 03:50 AM
Irocz327's Avatar
Irocz327 will become famous soon enough
Not to thread jack but I just order a set of soft 8s 15x8 for my truck just curious how big of spacers would a guy need to clear the calipers? Im not afraid to do some filing if nessesary but dont want to if i can get away with spacers &not have a huge differance in width from front to back and yes i know the rear is aready narrower then the front. Sorry again for jacking just thought the answer could help both of us. -Mike
Old Mar 21, 2012 | 10:53 AM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
I have 15x7 soft 8';s with 4.25 backspace. my fronts rubbed when I installed them (on the caliper) A little file and they are good now
-OSS
Old Mar 21, 2012 | 02:49 PM
azzr2's Avatar
I grabbed these from autozone out of desperation until i can get some good ones ordered.
Dorman/AutoGrade 5/16 in. thick 4 1/2 - 5 1/2 in. bolt circle 5 lug wheel spacer
AUTOZONE WHEEL SPACER
They were 18 bucks per set of 2.
