Just Looking For Some Help
Old Nov 9, 2009 | 09:52 PM
pbrubaker12's Avatar
pbrubaker12 is on a distinguished road
Default Just Looking For Some Help
Hey guys...I'm new here and I just had a couple questions
I really don't know that much about cars but I'm trying to learn and I figured this would be a good place to start.
I have a 2001 Blazer S-10 LT 4WD 4-Door V6 with stock everything I believe (I just bought it a couple months ago)
I was looking for some new rims and tires and I have absolutely no idea what to look for =/
What I was hoping you guys could help me out with is to just list the basic information of the maximum rim size, wheel size, backspacing, bolt pattern, etc. that I should look for without having to lift it.
Thanks a lot guys and I hope you can help!!
Old Nov 9, 2009 | 10:13 PM
ABN31B's Avatar
use the search function and look for things like 'stock wheel specs" and things along those lines...
you CURRENT rim is a stock 15"x7" alloy with 6" of backspacing.... THAT is the key when getting a new rim. you have a 4wd and the BACKSPACING is a huge deal here. go too small and you'll rub like hell if you get bigger tires...
biggest tire you can run stock is 30x9.5r15, probably rolling on 235/70r15's or 235/75r15's right now. to go any further we would need to know what you are looking for BUT try the search function first. it will turn up a TON for you
Welcome to the forum BTW
Old Nov 10, 2009 | 03:12 PM
I found these rims that are 15"x7" with a 5x4.75" Bolt Pattern...
However, it only seems to come in 4" and 4.25" backspacing...
Is 4.25" too small?
Cragar Soft 8's
http://www.summitracing.com/parts/CRR-3975734P/
Old Nov 10, 2009 | 07:43 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
They'll fit but they will stick out the wheel well about 2". Search Cragar Soft 8 and you should find pics of them on 4x4's here or try s10forum
santmire
May 28, 2011 01:39 PM
BlazinAtlanta
May 23, 2010 02:42 AM
camaro91boy
Feb 8, 2009 11:37 PM
kmd1776
May 16, 2008 07:44 PM
muleman
Sep 28, 2007 02:07 PM
