Lug nuts for cragar soft 8s
Old Dec 1, 2010 | 11:43 AM
Bosgarage57's Avatar
Bosgarage57 is on a distinguished road
im looking into getting some monte carlo rims for my 4wd blazer, I know they will stick out a little further, and that doesnt bother me, but will it have adverse problems on the car? Also someone mentioned I might need different lugnuts that will move the rim to the center when tigtening, anyone have a clue what thats about and where I could find some?
Old Dec 1, 2010 | 01:42 PM
99 blazer's Avatar
99 blazer is on a distinguished road
Ok i got the wheels but they rub the brake caliper just a lil bit
Old Dec 1, 2010 | 05:19 PM
Benedict1337's Avatar
you know another member on here had that problem but you and him are the only ones who I've ever heard this happening to. are you sure your not putting them on backwards?
Old Dec 2, 2010 | 01:08 AM
99 blazer's Avatar
No there going on correct. its just a hair..I dont Know if I should grind the caliper a little or what..who was the other member?
umm this is what i bought could it be 4in backspacing?
http://www.jegs.com/i/Cragar/260/397...oductId=754162
Last edited by swartlkk; Dec 2, 2010 at 07:04 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 2, 2010 | 01:37 AM
mdehoogh's Avatar
Does it interfere on all the wheels or is it just one specific wheel? Never heard of this happening so I don't have much advice. Make sure your brake pads are seated properly in the caliper.
Backspacing shouldn't affect the caliper clearance though. My 4" backspaced wheels (not cragars) don't hit anything.
Old Dec 2, 2010 | 01:59 AM
99 blazer's Avatar
I only tried one rim. Gonna try another tomorrow..and the brakes havent been changed in a while( still look good) but i would think there seated right..have atleast 20 k on them
it may have been the caliper bracket it was rubbing
Edit* I tried another same issue..They are sending me new ones cause these are all nicked up. They said if i have the same issue I could use a Spacer..Is that a good idea or should I grind the caliper the little bit that I need?
Last edited by 99 blazer; Dec 2, 2010 at 12:02 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 3, 2010 | 03:17 PM
99 blazer's Avatar
anyone? A buddy put 15s on his k5 blazer and had to grind the caliper a little and everything is fine..whats everyones oppion run a small spacer or grind the caliper a little?
Old Dec 3, 2010 | 03:27 PM
I'd run the spacer if you have the money
Old Dec 3, 2010 | 03:35 PM
99 blazer's Avatar
there like 11 bucks for two..spacers are a little dangerous tho arent they?
this what they recomended
http://www.jegs.com/i/Mr.+Gasket/720/2370/10002/-1
Old Dec 3, 2010 | 03:49 PM
well yes and no... those yes. any spacers that don't extend your studs are dangerous because you won't tighten the lugs to factory spec. and your wheels could fall off or you could break off a stud
