Max tire size for 2004 Zr2?
Hey Everyone,
I am looking for new tires for my 2004 ZR2 and was wondering what's the largest tires that will fit without having to modify the wheel wells. Thanks, KarlofZR2 |
From listening to other members 30" but I'm not sure if the zr2 is any different in terms of being able to run a bigger size tire or not.
31" is what came stock on ZR2's. so with a tbar crank and shackle lift, or BL you can probably fit 32" with very little rubbing if any. ive heard of people fitting 33's with a tbar and shackle lift, but that involves cutting and trimming flares and valences.
to sum up: 31's if you have no lift, 32's will be tight. 32's if you do a tbar and shackle lift. (may have to trim for offroad flexing) 33's if you do a BL and tbar and shackle lift. (may still require some trimming for offroad flexing) |
Originally Posted by Kr.Fabs
(Post 341794)
