New 20's
Old Jan 2, 2012 | 03:05 PM
Blaza boi's Avatar
Blaza boi is on a distinguished road
Default New 20's
I just traded my 22s for some 20s reason was wanted smaller rims to get a bit bigger of a tire. Now just debating on what tire i should go with. My truck is lowered 2 n front and 3 in back. Any opinions?? Want a bit bigger of a tire and a bit wider than wt i have now and i dont want to rub
Old Jan 3, 2012 | 10:39 AM
Blaza boi's Avatar
No body has any suggestions??
Old Jan 3, 2012 | 11:07 AM
TripleBlackBlazer's Avatar
What size tire did you have with the 22s? Did they rub? What backspacing and offset are your new 20s? How wide are they? What kind of tread do you want? What research have you done on your own?
We need more information to help you.
Old Jan 3, 2012 | 12:14 PM
Blaza boi's Avatar
Tire on 22 was 255/30r20
They rubbed on my frame but the 20s are a little diff offset and narrower.
I found 255/40r20 to be the same as the 22 just about
Old Jan 4, 2012 | 08:34 AM
I'm guessing you meant 255/30/22 for the first tire size.
Check out Tire size calculator if you haven't already to get a good idea of a comparable tire.
With 255/40/20 you're getting about an inch more sidewall with the same width. It will really depend on how wide your 20s are and the backspacing/offset to determine if you will still rub or not.
Old Jan 4, 2012 | 09:03 AM
Blaza boi's Avatar
Yes i checked it out i know the sidewall is going to b bigger thats what i want
2000jimmbo4x4
Aug 23, 2010 07:10 AM
yazan84
Dec 30, 2007 11:19 PM
thegr81
Oct 19, 2007 08:18 PM
