New Rims- hub cap issue
Old 09-02-2014 | 08:30 PM
teckguy's Avatar
teckguy is on a distinguished road
Default New Rims- hub cap issue
Hi guys, I managed to pickup my new Superior 15" rims with 4.75" bolt pattern and 6.5" depth. Installation is on a 2005 Jimmy 2 door with 4wd.
No problems with fit however, the hub cap covers for the front rims don't quite fit due to the length of the axel extending thru the rim to the back of the cover...I am shy by maybe a 16th of an inch in the cap .
One thought is to cut away some of the material from the backside of the aluminum hub cap itself and the other to grind a bit of material from the end of each front axel. Best advise?
Thanks!
Old 09-02-2014 | 09:36 PM
rexmburns's Avatar
Super Moderator
I'd go for removing material from the hubcap first and see if you can make that work.
Old 09-03-2014 | 01:32 PM
teckguy's Avatar
Default Hub caps
Trying to cut the centre hole larger in these 1/8" thick aluminum hubcaps with a grinder running from my large shop compressor is nearly impossible without breaking something...looks like shorter axles with a cut off saw or big *** angle grinder here we come.
Old 09-03-2014 | 02:13 PM
rexmburns's Avatar
Super Moderator
Hope you never have to replace a hub or you will be replacing the axle to unless you are crazy careful not to get into the threads but I do to think there is a lot of wiggle room there!
Old 09-03-2014 | 04:31 PM
rexazz2's Avatar
I would likely grind down the axle stub
they are usually fairly rounded and the threads are not usually that close to the end
Old 09-03-2014 | 04:59 PM
rexmburns's Avatar
Super Moderator
Thanks for the additional info Rex it's been a bit since I've seen the end of an axle stub!
Old 09-03-2014 | 07:11 PM
rexazz2's Avatar
a 4inch electric grinder will do the job , the axle stub is not that hard
just keep it moving around and try to chamfer the edge if possible
careful around the wheel studs and be mindful of the sparks
OMG I sound like my grade 11 auto shop teacher
Keystoneguy91
Tires and Wheels
10-27-2012 09:40 PM
OH_VDUB
02-02-2012 03:26 PM
ramairmustang
10-25-2010 07:31 AM
rxm6
05-25-2010 10:38 AM
BigGreenMonster
08-24-2006 01:32 AM
Quick Reply: New Rims- hub cap issue
