new tires
Old Jul 20, 2009 | 11:44 PM
sk8indigomoon247's Avatar
sk8indigomoon247 is an unknown quantity at this point
Default new tires
im getting my new tires either this week or next,
depending on when the child support comes in, and
if i can fit the size i want with a tbar crank of 1.75" and 2" shackles
will that be able to fit 31X10.5"?
Old Jul 20, 2009 | 11:45 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
you may have to trim some.
Old Jul 20, 2009 | 11:49 PM
even on stock rims?
Old Jul 20, 2009 | 11:55 PM
mikeinwi's Avatar
you need 2" of lift to clear 31's. you might get lucky and not have to trim, but chances are youll be trimming atleast a little bit.
Old Jul 20, 2009 | 11:58 PM
and how do you do that? well what about 2" in the front then and the 2" shackles i ordered??
does that work with no trimming? haha don't really wanna mess nothing up
Old Jul 21, 2009 | 12:01 AM
mikeinwi's Avatar
you can crank your tbars 2" but itll tear apart your cv's, i suggest either getting a 2" body lift or just cranking your tbars 1.5-1.75" and triming your front valance and the rear of your front fender. also keep in mind that any crank on your tbars will result in unwanted wear and tear in your front end.
Old Jul 21, 2009 | 12:02 AM
also i have another question about how much would an alignment cost? i have no idea
bc im going to the goodyear place and they have in their ad that they have price match and the 31x10.5" are 130 at tirerack.com
and there the 235/75/15 are 126 or 8
and if i go ahead and do the shackles and tbar before ill save some trouble
Old Jul 21, 2009 | 12:03 AM
oh ok, well im replacing a bunch of the front steering and what not ina couple of weeks also
inner and outer tie rods, upper and lower ball joints, pitman and idler arm
mikeinwi's Avatar
an alignment will be anywhere from $25-50.
Old Jul 21, 2009 | 12:04 AM
oh ok so not to much then? sweet, its a computerized alignment with 10$ off coupon, and my parents are paying 300$ of the total cost
