New wheels or spacers
I have a 2wd Blazer that I put a 2" suspension lift on and tires that are somewhere between 30" and 31". The tires rub only at full lock and I know my best option would be to find some wheels with less backspacing but I'm having trouble finding any wheels with less than 3.75 backspacing. My wheels are the factory with 4" backspacing so would the quarter inch really make a difference or should I get some spacers? If I should get spacers what size would you suggest?
Yes, you could space them out 1/4" to check clearances. I wouldn't drive around like that because the studs might be getting too short and not have proper thread engagement.
I tried searching quickly for a definitive answer but couldn't find anything quickly. I thought 2wd wheels had the same specs as third gen Camaro wheels, in which case they would have a 4.5" backspacing, not 4".
96jimmyslt4x4
Apr 2, 2011 01:13 PM
brazilian blazer wanter
Tires and Wheels
Sep 30, 2010 09:12 PM
