-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   Offset/Backspace of stock/factory rims (https://blazerforum.com/forum/tires-wheels-13/offset-backspace-stock-factory-rims-51432/)
christian1984 Nov 11, 2010 12:54 PM
Hi guys,
iīve got a question about the ofset/backspace of a 1995 Chevy S10 Blazer.
I want buy some new rims, but in germany the regulation of car modifications are very hard.
The rims must not stuck out of the Fenders.
Now, I have the stock rims with 265/70R15 on stock rims, like these on my blazer.
To decide which rims would be legal, I would like to know what the offset of these rims is.
I searched everywere, but I nowhere found the offset.http://carphotos.cardomain.com/ride_...0004_large.jpg
If anyone could help me,
I would be very happy.
Thanks a lot
Greetings from Germany,
Christian
OILCOUNTRY Nov 11, 2010 12:58 PM
Back spacing is 6''
nj4x4blaze Nov 11, 2010 01:05 PM
Correct
christian1984 Nov 11, 2010 01:10 PM
Thanks for your answer!!!
The offset is so much?
Ok, that explaines why the tire rubbing on the frames, while I have 30mm wheel spacer on every front wheel.
I want want new rims, because I donīt like wheel spacers.
Now I can calculate the Offset of the new rims.
Fortunately, no german police officer have no notion about american cars.
Thank You!!
nj4x4blaze Nov 11, 2010 02:31 PM
Look for a wheel with a 5" or 5.5" backspace.
christian1984 Nov 11, 2010 02:40 PM
Ok, thanks, but iīve got a little dumb question, yet.
How did you measure the offset?
From the inner side of the Rim?
I think itīs so much, the rim-width is only 7".
mdehoogh Nov 11, 2010 02:41 PM
The offset is +51 and the backspacing is 6 inches.
The backspacing is measured from the hubface of the wheel to the inner edge of the wheel.
Once you have the backspacing, you can calculate the offset
http://image.mustangandfords.com/f/2..._backspace.jpg
http://hubgarage.s3.amazonaws.com/ph...son_detail.JPG
christian1984 Nov 11, 2010 02:44 PM
Offset and Backspace are two different datas?
I donīt know, because in Germany thereīs only one data.
I think it should be the offset.
Ok, so I learned some new things.
Thanks
mdehoogh Nov 11, 2010 03:11 PM
Thanks
That is correct,
Offset is the distance from the center line of the wheel to the hub mounting face.
Backspacing (or rear spacing at the bottom in the picture below) is the distance from the hub mounting face to the inner edge of the wheel
http://performancexcessories.com/Offset5.jpg
It can be confusing trying to match up several different measurements and aspects of the wheel
TripleBlackBlazer Nov 11, 2010 03:23 PM
Dehooooooogh to the rescue!
