Putting 95 Z28 wheels on blazer
Old Feb 24, 2024 | 03:44 PM
damean941's Avatar
damean941 is on a distinguished road
Default Putting 95 Z28 wheels on blazer
I have a set of Z28 wheels, they are 16 inch, everything fits great. The center bore , bolt pattern etc. the only problem I have is the rims are 16 x 8 so the rear rims ride against the rear brake lines. I thought of putting 1 inch spacers with hub centric on to solve this issue. I actually only need about a half inch so I could go with 1/2 inch spacers or 1 inch. Has anyone done this swap before? Are there any other problems I may run into? Any help greatly appreciated
Old Feb 24, 2024 | 09:27 PM
AJBert's Avatar
It would be cheaper to buy a tube bender and bend the tubes. Spacer only move the rims out, though that might work.
Old Feb 26, 2024 | 10:28 AM
El_Beautor's Avatar
You'll also want to check that the front doesn't rub when turning at full lock.
If you have the rims I believe you do, then keep in mind that they have 6.8" backspacing, vs the 6" that is standard on the factory 15x7" rims from a 4x4 S-series truck. So the inside lip of the rim and tire sit just over 3/4" inboard vs the factory setup.
I'm running a set of these rims on my truck with my winter tires, but I have a ZR2 rear axle (3" wider than factory 4x4 axle) and 1.5" spacers on the front.
Old Feb 27, 2024 | 11:48 AM
damean941's Avatar
Default Z28 wheels swap
Thanks for the info, I bent the brake line hanger as much as I could, which gave me about an extra 3/8 space away from the tire. I have ordered 1 inch hub centric spacers and think this will solve the issue of tire and wheel scrub. As for the front wheels it makes a little contact when fully turned, but just a small amount, I think the spacers will solve this as well. Thanks for all the help and input.
Old Jun 24, 2024 | 03:54 PM
S10_Phazer's Avatar
S10_Phazer is on a distinguished road
Did you ever resolve this issue? I just got a 2dr 4x4ls and I have an extra set of 16x8 Firebird formula rims I was thinking about using.
Old Jul 4, 2024 | 08:50 AM
Dameanfl's Avatar
Dameanfl is on a distinguished road
Default Z28 wheel conversion
95 Z28 wheel conversion
Old Jul 4, 2024 | 08:58 AM
Dameanfl's Avatar
Yes. They fit great no problem. I actually can run the wheels without the spacers but get a slight scrub at full turn , but not to the point it's a issue. But I installed 1 inch spacers and everything is fine. ( You can run 1/2 spacers and that solves any issues) I ended up running 265/70/r16 tires and it gave it a lift around 1/2 to 3/4 inch without installing lift kit and i didnt have to adjust the torsion bars . But that is about the max tire size I can go without having to lift it. Everything seems to be fine and rides well too. Although your speedometer may be 5 to 20 miles off. Mine is approximately 5 miles off . Sorry to do long to reply been busy with a lot of projects
BrinkDiamond
Tires and Wheels
Jul 4, 2024 09:05 AM
ZEPPLIN23
Tires and Wheels
Dec 9, 2013 03:05 PM
madsert4
Tires and Wheels
Jan 30, 2010 09:28 AM
phrankguy1
Tires and Wheels
Aug 1, 2009 12:27 PM
Ash
Tires and Wheels
Sep 29, 2008 04:01 PM
