Question
Old Jun 28, 2009 | 03:24 PM
Andr3ws's Avatar
Andr3ws is on a distinguished road
Default Question
I have these rims I want to put on my Blazer, but the bolt pattern is 139.7 what would I need to get them to work?
Old Jun 28, 2009 | 03:29 PM
5-bolt rims? That would make for 5 lugs on a 5.5" bolt circle. You would need adapter rings for these to work. Then you have to worry about the backspacing on those rims. If they are already less than 6" back spacing, you may get into trouble...
Old Jun 28, 2009 | 04:54 PM
Andr3ws's Avatar
Yeah they are 5x5.5 5 bolts. What do you mean by the backspacing?
Old Jun 28, 2009 | 05:22 PM
TripleBlackBlazer's Avatar
Here's a link CLICK from a thread that was just posted 3 days ago.
Have a look around, there's plenty of resources in the threads that are already posted.
Old Jun 28, 2009 | 05:27 PM
Sisk's Avatar
Backspacing:
Old Jun 28, 2009 | 06:30 PM
Andr3ws's Avatar
Thanks that picture really helped. I will be okay in that area. So how much would these adapter rings cost for all 4?
Old Jun 28, 2009 | 07:08 PM
bandidolenny's Avatar
Look here for wheel adapters. http://shop.ebay.com/items/?_nkw=whe...ters&_osacat=0
As far as backspacing is concerned... the wider the wheels, the more attention you need to pay to this issue. I recommend staying as close to the stock bs as possible. You may also need a lift depending on what size tires you want to run.
Old Jun 28, 2009 | 09:58 PM
Andr3ws's Avatar
Okay as you guys can tell I'm clueless about this **** unless it's for car audio lol....two questions:
1. If my backspacing is more than 6 inches what do I have to do? Because I just measured the rims, and they are a little more than 6.
2. What size wheel adapter would I need to put these on a 98 s10 blazer?
(the rims are 139.7 5 lug, 24's)
Old Jun 28, 2009 | 11:30 PM
How are you measuring backspacing?... if you look at Sisk's picture above, you will see that the inside edge of the rim is 6.5"s from the part that goes up against the hub.
If your bs is just over the 6' mark then I would go with a 1" spacer.
24"s?!?... really now?... I am guessing that you are not gonna be doin much off-roading!... lol Please post some pics when you get them on!
Old Jun 28, 2009 | 11:59 PM
Andr3ws's Avatar
Okay I got you...and no I'm not really the off road type lol. I will post pictures as soon as I get them on. Go big or go home you know.
