Quick Question
Old Jun 18, 2010 | 09:11 PM
mrshaneb's Avatar
mrshaneb is on a distinguished road
Default Quick Question
I am thinking of going with 15X10 or 15X12 Rims either 4.5" or 5" back spacing, with a 31X10 L50 R15 Mickey Thompson Baja Claw Radials. I have a 1997 2Dr Blazer with the Sport Touring Suspension. Will these fit without out rubbing?
Sorry, I'm tired and to lazy to search right now.
Picture of my Blazer:
Old Jun 19, 2010 | 03:19 AM
Mczuk's Avatar
Mczuk is on a distinguished road
for one those rims are too wide for a 10.50 tire, a 15 x 8 would be better, and no they won't fit without lifting. Most use a t-bar crank and shackles, cheap and easy.
Old Jun 19, 2010 | 04:41 AM
ImScrewed92's Avatar
No... not at all. On factory rims, 31x10.50x15's will fit with a 2 inch body lift. And even then you will rub the frame and possibly the sway bar when turned to the lock. And the factory wheels have 6 inch backspace. If you went down to 5 or even 4.5 inches, you will rub pretty good with 31's. Because your wheels would sit outside the fenders a inch, 1.5 inches.
For 31's and 4.5 inch backspace 15x7 wheels, you'd need a 2 inch body lift, shackles and tbar tweak. And even then you would still have to remove your mudflaps, trim the bottom of the front bumper and possibly cut the back of the front fender some. But after all of that it would look pretty bitchin'! And just so you know the bolt pattern is 5x4.75, or 5x120.67mm.
Old Jun 19, 2010 | 02:09 PM
mrshaneb's Avatar
This is probably a dumb questions but how many turns of the tbar do you need to lift it two inches?
Never mind I read the Tutorial.
Ok, for the rims I want as notated in the original post, what size tires would be the best?
Last edited by rriddle3; Jun 21, 2010 at 08:20 PM. Reason: COMBINING CONSECUTIVE THREADS
Old Jun 19, 2010 | 11:18 PM
You can run 31x10.50x15's on 15x10 rims. There is a member here by the name of "bandidolenny" that runs this combo with 5.5 inch backspacing, and 31 inch BFG AT's. If you search for that name and go to his photo gallery you will see what this combo is like.
But he has a 2 inch body lift, a 2 inch suspension lift, trimmed the fenders and the fender flares AND added wider flares to cover the tread of the tire. Some state's won't allow tires to not be covered by at least a flare, normally refered to as exposed tread. Just something to keep in mind and check on to see if it's required for inspection or agianst any laws.
But as I said he has 4 inches of total lift and still had to cut the front and back of his fenders. Here is some link to his photo gallery.
https://blazerforum.com/forum/members/bandidolenny-13624-albums-1998-blazer-z85-10/
Old Jun 21, 2010 | 09:13 PM
mrshaneb's Avatar
Thinking about a 29X10.50R LT15 on a 15X8 rim. There shouldn't be any rubbing with this tire and rim combo correct?
Old Jun 21, 2010 | 10:37 PM
Mczuk's Avatar
I had 29x10.50 15 thornbirds on my Jimmy on 15x8 rockcrawlers and at stock height they rubbed. The tires were as big as my friends 31 10.50 bf all terrains. I cranked the t bars a little, trimmed the back of the front fender a little and used flares. I will try to post a pic later, well it will be a pic of a pic, I didn't have a digital camera back then.
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
88s10Blazer
Nov 10, 2006 05:49 PM
88s10Blazer
Sep 26, 2006 10:19 AM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
