RIM FITMENT ?????
Old Jan 25, 2008 | 02:12 AM
erik102207's Avatar
erik102207 is an unknown quantity at this point
Default RIM FITMENT ?????
Hey guys! I need to know ifthese wheels fit a2004 Blazer 2WD? If so any recommended tire size?WHEEL SIZE: 20x7.5 /BOLT PATTERN: 5-100 / OFFSET: 42mm.If notany info you can give on what the correct fitment I should be looking for is as far as the bolt patter and offset for 20" rims would be appreciated. Thanks in advance.
Old Jan 25, 2008 | 07:25 AM
Default RE: RIM FITMENT ?????
No. bolt pattern is incorrect. 5x100mm == 5x3.93in. The bolt pattern of your truck is 5x4.75 or ~5x120mm. The backspacing is close to correct, but with that bolt pattern, it would never fit onto the lugs.
Old Jan 25, 2008 | 11:03 AM
nj4x4blaze's Avatar
Kyle his truck is 2wd not 4wd so that 42mm offset will not fit unless he is going to run spacers. Like Kyle stated above your bolt pattern is 5 x 4.75 and offset should be 4mm - 10mm. Here's a link below that explains everything for your 2wd. Not to link another site, but it does have good info that you can read. Please notethat offset+35mm and higher will fit 4x4 blazers.
http://www.s10forum.com/forum/f14/fo...offset-107156/
Old Jan 25, 2008 | 12:32 PM
Yeah I just missed the 2wd thing. Thanks for catching that. I have too much on my plate right now...
Bottom line is they don't work.
And I have posted diagrams detailing backspacing/offset/etc before. A little bit of searching on this site will turn them up...
scprosportsman
Tires and Wheels
May 29, 2011 05:39 AM
BLAZ-N-IT
Tires and Wheels
Oct 29, 2010 12:41 PM
wolv2401
Tires and Wheels
Feb 28, 2007 01:42 AM
drperry
Tires and Wheels
Jan 28, 2007 05:40 PM
