Rim Help!
Old Aug 19, 2015 | 04:57 PM
xXPurpleDogXx's Avatar
xXPurpleDogXx is on a distinguished road
Exclamation Rim Help!
I have a 1999 Blazer 4dr 4wd stock rims, and I was wondering what I need in regards to information (offset, size, etc) to find rims for it that will fit on without any problems. I know I will need new tires (thats a given) but what should i look for when I'm looking for new rims. I don't want the speedometer to be wacky. I'm basically looking for larger rims which means lower profile tires. Correct? Any help would be appreciated. Currently, my tires are P235/70R15 M+S on both front and back. Thanks guys
Old Sep 2, 2015 | 03:47 PM
Almost a month. Any help?
Old Sep 2, 2015 | 05:28 PM
LeWhite's Avatar
Late model Camaro 245 x 55 x 18 that are Z rated! On my 2002 2wd they needed 2.24in adapters. On a 4wd the offset would be about right but the bolt pattern is very slightly different. ( about 0.030).
Old Sep 3, 2015 | 08:16 AM
Jamaroon's Avatar
You need to match the overall diameter for your speedo to be correct without tuning.
You can google tire size calculator to compare sizes, or do the math.
Your current tires are 235mm*.7*2+15" = 27.95" diameter. So you need to find a combo that will give you that overall diameter.
Stock 4x4 wheels are 15x7 with 6" backspacing. 5x4.75" Bolt pattern. To have the least chance of any problems you need to stay as close to those numbers as possible.
evuldrporkchop
Mar 4, 2013 01:20 AM
mogley99
Tires and Wheels
May 6, 2007 07:12 PM
mogley99
May 3, 2007 05:06 PM
kmt
Jun 24, 2006 12:34 PM
demjjm
Tires and Wheels
Oct 3, 2005 04:44 PM
