Rims/Tire Question...
Old May 29, 2008 | 10:17 AM
MHPrior80's Avatar
MHPrior80 is an unknown quantity at this point
Default Rims/Tire Question...
Ok everyone i have decided to go with this setup...first:
The truck when im done will have:
a 2 in. body lift
2.25in lift shackels
2 in. ruff country shocks
add a leaf ( 1 on each side )
and a 1 in torsion key lift
now the wheels i have are 15x7 with a back spacing of 4
im gonna buy wheel adapter/spacers ( 1.25 in in front/2 in. in rear ) i need the adapters because the bolt pattern is 5x4.5 on the new rim. with the adapter/spacers...will this be a big problem or will just the minor trimming need to be done to make everything work. the tires i want are the bfg mud terrain...i know i want 33s but which would be better 33x1150x15 or 33x1250x15? what does everyone reccomend for this to work out properly? thanx in advance
ps..im not really taking it off roading, my truck just goes down alot of dirt roads, and deer camp.
Old May 29, 2008 | 11:00 AM
Default RE: Rims/Tire Question...
Wow... You won't have much, if any problems in the back, but you will be sticking each wheel 4" further out...
In the front, you are moving things a total of 3.25" out which would be problematic with much smaller tires... Using 33's, I'm afraid you will have to really bash in your firewall to get it out of the way. The reduction in the backspacing is making things MUCH worse.
Old May 29, 2008 | 12:58 PM
MHPrior80's Avatar
what would u reccomend for the front then? 2 in spacer/adapters all around? i was trying to go with a smaller sized adapter to try to even out the front and back wheels...as it looks like the back wheels are tucked in a little more then the front.
Old May 29, 2008 | 01:13 PM
MHPrior80's Avatar
or do u think a different size tire would be in order? any reccomendations are appreciated. thanx
Old Jun 1, 2008 | 07:51 PM
MHPrior80's Avatar
Anyone??
Old Jun 1, 2008 | 07:54 PM
I wouldn't run any spacers... If I were you, I would find another set of rims... 3.25" is a LOT to move a tire out!
On a side note, please try not to post consecutively unless you have waited atleast 24 hours... If you have anything further to add to your post within a 24hr window, please use the edit function to include it.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
97winterblazer
Tires and Wheels
Sep 24, 2010 07:51 PM
m.sterner
Tires and Wheels
May 16, 2010 09:30 PM
Tippman7641
May 7, 2008 03:29 AM
88Blazin
Oct 17, 2006 08:33 AM
