So to keep rims simple
Basically im not plannin on liftin the blazer just yet. my buddy got me the rancho shocks that are adjustable in stifness and i just picked up some sweet a$$ tires. i just wana dress up with bada$$ feet to go with those shoes along the cragar soft 8 idea but am afraid of the rubbin my buddy gets in his truck. since im CPU illiterate can someone link me to the best ideas for new rims keepin it 15 x 7 without the rub..
Originally Posted by mrkevinmjr
(Post 386978)
There are, in fact, very few wheels that will fit like your stock rims. Most all rims available don't have the necessary offset and they will stick out some. The amount of rub is dependent on size of the tires, specs on the wheels and ride height of your truck. This website specializes in 4WD Blazer gear and they have a few wheels that will fit the best: http://shop.synergyoffroad.com/Wheels-and-Tires_c25.htm |
basically i kept the standard tire size when i bout the new tires. i didnt want to change too much because im still financing and dont wana risk too much money. but i do need to know what i can do to add to my blazer that my wife sais is boring but its my second love lol.
will the change up from a 6 in stock back spacing to a 4.5 inch back spacing rub without lift modifications |
Try a set of these, they're older but they're Dick Cepek, stock rim size on a smaller 60 series tire
http://i1043.photobucket.com/albums/.../Photo0060.jpg |
whats the backspacing... they look awsome
I think it's 4 or 4.5, it's pretty much stock backspacing
u have a 4x2?
Yupp, they're pretty common, 5 x 4.5 bolt pattern, 15x8, and i believe 4.5 backspacing.
5x4.75 is stock bolt pattern, small difference but depending on the lug nuts enough to put unwanted stress on your wheel studs.
Stock backspacing is 6". So 4.5" would make the wheels stick out 1.5" wider. Those Cepek's look like they might be 6" or 5".
My cragars never rubbed on mine? they are actually for sale right now.
If Jukebox is 2wd, and those rims sit like that I'd say they're in the 4.5" BS range. If he's 4wd then they're 6".
At most you'd have to crank half an inch in the front to clear stock size tires on a 4.5" backspaced rim. You may also want some spacers in the rear to even out your track width. |
i need a 15 x 7 stock size relplacement that will not rub.... hmmmm
my cragars were 15 x 7 with 4'' of backspacing... so they stuck out 2'' and they didn't rub... they did grind the against the caliper a little but i shaved some off so they didn't grind at all. They didnt make the wheels rub though.
shaved the rim?
(Post 430836)
shaved the rim?
caliper... like a tiny tiny bit though... trust me I am too paranoid to do something dangerous to any of my vehicles. |
