steel rim help! Please
Old Nov 30, 2007 | 11:24 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default steel rim help! Please
i have a question that may sound stupid but its bothering me...i have stock rims on my 96 blazer and i want rims but i want black ones but dont have money yet for rockcrawlers. so i was wondering about black steel rims like the ones on the police cars with the chrome hub in the middle is that black steel rims like that that will fit on my blazer? they are inexpensive and if i put a chrome hub on it i think it will look sweet.....thanks!
[/align]
Old Nov 30, 2007 | 11:34 PM
thegr81's Avatar
Default RE: steel rim help! Please
The ford crown victoria ones wont fit on your's, I would search for old caprice steel wheels with the chrome hub on them those will fit!! Hope this helps and one other thing is that you might need spacers for those to cause I think there fwd offset!!
Old Nov 30, 2007 | 11:36 PM
Banned
can you give me specific things to look for...im inexperienced in the wheel/tire dept.. thanks i really appreciate it
[/align]
Old Nov 30, 2007 | 11:41 PM
thegr81's Avatar
Ok well firstoff in order to use the old caprice wheels your going to need wheel spacer's probably 2 inch spacer's. Now when you get spacer's you have to get the one's with your lug pattern on them as well as the bolt pattern to bolt onto your lugs. Then you can put the caprice wheels on and they will sit flush with the body of your blaze and you wont have and problems turning and losing turn radius and also rubbing in the back will be no issue as well. Spacer's push the wheels out for clearance and prevent any rubbing issue's.
Old Nov 30, 2007 | 11:42 PM
mdehoogh's Avatar
you need wheels with a 5 on 4.75 (5x120.65mm) bolt pattern. GM and BMW are the only ones with this bolt pattern so wheels off a jeep or ford are not gonna work
Old Nov 30, 2007 | 11:43 PM
Banned
the rims for the blaze are 15x7 right? the old caprice wheels are identical? thanks for being patient and explaining
[/align]
Old Dec 1, 2007 | 12:07 AM
mdehoogh's Avatar
stock blazers are 15x7 but with your stock tires, you could probably fit 15x6 and 15x8....
if the AWD blazers have longer axles like a 4WD (im sure they do) then you also want to look for wheels with 6" backspacing.
Old Dec 1, 2007 | 12:11 AM
Banned
are the older s10"s...do they have black steel rims that i can put on? if i need 6" backspacing for the awd if the rims are only 4inch backspacing can 2 inch wheel spacer make up for it?
[/align]
Old Dec 1, 2007 | 12:17 AM
mdehoogh's Avatar
no, 2inch spacers will make it worse. they would make it so its at 2" backspacing.
this shows what backspacing does
wheel spacers mount on the hub and then the wheels would mount on the spacers.
evuldrporkchop
Mar 4, 2013 01:20 AM
PaulO2288
Tires and Wheels
20
Sep 18, 2009 04:09 PM
MindlessCorpse
Sep 22, 2007 06:29 PM
kmt
Jun 24, 2006 12:34 PM
