tire ?
Old Aug 22, 2007 | 02:33 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: ok will this work
gonna go ahead and warn you that theose superswamper thornbirds will be terrible for everyday use and they might last you 20,000 miles... they are not designed for on road use... if you like the interco superswamper look, maybe you should try looking at the interco TrxUs....... they would be a bit better for everyday use, plus im pretty sure a 11.5" wide tire is gonna rub your frame and sway bar, i know my 9.5's come very very close to the frame at full lock....
TrXus: http://www.truckaddons.com/Catalog/s...MudTerrain.htm
if you are doing a body lift then the 31 x 10.50 will fit fine....
Old Aug 22, 2007 | 10:06 PM
blazer123456789's Avatar
blazer123456789 is an unknown quantity at this point
yea i thought they would be to wide and i talked to some friends today and they said the same thing about not lasting long
thanks for the sugestion
i thik i might be looking into some differnt ones now im just trying to reseash them befor i buy everyones help is greatly apprciated
PostRelease
Oct 8, 2010 03:01 PM
PostRelease
PostRelease
butters
May 15, 2009 08:06 PM
Blazertrish66
Apr 29, 2008 07:54 PM
