wheels spacing
Old May 11, 2009 | 08:54 PM
jimmy1996's Avatar
jimmy1996 is on a distinguished road
Question wheels spacing
ok so i wanna put wheel spacers on my 96 jimmy. i have a few questions. first does any one no what bolt patern my jimmy has? its got the heavier rear end in it if that helps. what size of spacers should i get? is 1 1/2 to big? any help would be greatly appreciated, thanx.
~justin~
Old May 11, 2009 | 08:57 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the bolt pattern is 5x4.75 and i beleive that 1 1/4" spacers in the rear will even out the stance.
Old May 11, 2009 | 09:02 PM
jimmy1996's Avatar
thanx. how do u measure the bolt pattern? and i plan on putting them on all 4 wheels and adding the extenda flares.
Old May 11, 2009 | 09:13 PM
mikeinwi's Avatar
im not exactly sure how to measure bolt patterns, im sure if you googled it youll find a way. have you thought about finding new rims with a different backspacing instead of using spacers? i think new rims with a different BS would be a much safer option IMO.
Old May 11, 2009 | 09:16 PM
jimmy1996's Avatar
ya but im only 15 and im finnancialy chalenged haha would 1/2 ich spacers be enough or would that hardly even be noticible?
Old May 11, 2009 | 09:26 PM
mikeinwi's Avatar
if you go with 2" spacers on the rear and 1.5" up front you should be fine, if anything you might need longer studs in the rear but thats a cheap and easy project.
Old May 11, 2009 | 09:28 PM
jimmy1996's Avatar
ok thanxs, would it be stupid to like stick a washer on the lugs and then put my wheel on?
Old May 11, 2009 | 09:31 PM
mikeinwi's Avatar
if thats ur idea of a wheel spacer i wouldnt do it. im not sure why else you would put a washer on.
Old May 11, 2009 | 09:36 PM
jimmy1996's Avatar
lol ya but ill probly get 1 1/2 inch bolt on spacers then
Old May 11, 2009 | 09:42 PM
mikeinwi's Avatar
search ebay for wheel spacers, youll get plenty of results and should find some for pretty cheap.
