will 33s fit ......
Old Sep 7, 2008 | 12:19 AM
Blazin_1t_up's Avatar
Blazin_1t_up is an unknown quantity at this point
Default will 33s fit ......
if i get a 2 in BL and 2 in shackle if not wat is the biggest that will fit
Old Sep 7, 2008 | 01:39 PM
Verno's Avatar
Verno will become famous soon enough
Default RE: will 33s fit ......
If you drive straight, and never turn you should be ok.
Honestly, If you plan on any offroad driving, you'll have to trim ALOT.
Lets see, air shocks, AAL's, T-bar crank, am I forgetting anything?
Old Sep 7, 2008 | 01:48 PM
im doin thew tbar crank and the stuff i mentioned ... so wat size will fit and look good
Old Sep 7, 2008 | 03:19 PM
Verno's Avatar
ORIGINAL: Blazin_1t_up
31's in a AT
Here's a list of things Jigg did to a ZR2 Blazer, to be able to take it offroad with no rubbing issues.
On 33's.
2" BL
2.25" Lift Shackles
1" Tbar crank
Air Shocks
Add A Leafs
A bit of fender trimming
Old Sep 7, 2008 | 04:28 PM
NVANZEE's Avatar
i fit 31"s with a tbar crank and a 2" aal. with a body lift you might be able to fit 32's but it all depends on how agresiive the tread is and how much your suspensions is sagging.
Old Sep 7, 2008 | 06:46 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
It also depends on rim backspacing and tire width aswell.
Old Sep 7, 2008 | 10:38 PM
ok b/c i found a killer deal on some 33s...450 for all four mickey tompson mudd terains
abarone7411
Tires and Wheels
Oct 22, 2014 09:03 AM
fitrider150
Lifting Tech
19
Feb 7, 2010 01:44 AM
Blazen Along
Apr 7, 2009 08:40 PM
bksowers1
Nov 2, 2008 04:03 PM
tt0876
Lifting Tech
Jan 22, 2008 10:13 PM
