Will BFG's fit
What im wondering if 31/10.50/15 BFG A/T's or M/T's will fit on my 99 2 door with an add a leaf and a torsion bar crank. I would like there to be no rubing on the fenders. Rubing at full lock is ok. I would like to know how theses will fit on my stock ZR2 wheels and on aftermarket wheel with a 4.5" backspacing
RE: Will BFG's fit
add a leaf and torsion crank is not enough info for anyone to decide if you're tires will fit. We need a lift measurement.
To put you in the ball park...my 30x10.50s (on 15x8s with 4.5' of backspacing) rub on fender at the last 10% to full lock, and thats with 1.5' up and trimmed fenders. |
RE: Will BFG's fit
your stock ZR2 wheels? im assuming you have ZR2 wheels on a non ZR2?? if it is a ZR2 you will be able to fit them with no mods. If it is a non-ZR2 you need 2 inches of all around lift and 5-6" backspacing. They may still rub the frame at full crank..
RE: Will BFG's fit
Aaron where ya been?!?!? Havn't seen you around here in a while...had lots of 'wow a_tack would explain this better' threads recently:)
RE: Will BFG's fit
ORIGINAL: a_tack your stock ZR2 wheels? im assuming you have ZR2 wheels on a non ZR2?? if it is a ZR2 you will be able to fit them with no mods. If it is a non-ZR2 you need 2 inches of all around lift and 5-6" backspacing. They may still rub the frame at full crank.. |
RE: Will BFG's fit
theyre gonna rub with 4.5" BS... unless you trim the fenders a bit..
and wolfpack, i've been lurking around..lol in between jobs right now so i've been out doing yard work for extra cash.... by the time I can get online im too tired...haha but im back.. |
RE: Will BFG's fit
will they rub with the add a leaf torsion crank and a 2" body lift?
RE: Will BFG's fit
well no... but thats kindof a waste just for 31's... why not just the crank, shackles, and stock rim backspacing with 31's?
RE: Will BFG's fit
Well he wants the ZR2 stance...hence the lower backspace rims. 4.5' is manageable...I've only gone up 1.5' and only had a trim a minor bit, but then again that's with 30x10.50s not 31s.....
Haha...again..let's just go with a_tack on this one :D |
RE: Will BFG's fit
will 32's fit with a torsion crank, aal, and a body lift
| All times are GMT -5. The time now is 11:09 AM. |
