Will these crawler rims work out?...
Alright so i want to put these Pro Comp 152 series black crawler rims on my 2003 chevy 4wd 4dr blazer. I want to put these on with hopefully 30" mud tires, i have no lift on it. here is the link to the rims i want..... http://www.4wheelparts.com/Wheels/Ro...pn=PCW152-5761
The full specs of the rims are on the page. Please give me some feedback on whether these will fit on my blazer or not, right now i have american racing outlaw II's on and i dont like them cause they are "flush" with the tire and not concaved in. Also i want to switch to black rims and put mud tires on. Im running stock tires right now... Thanks |
they will bolt up, but you want be able to run a 30" tire on that rim without trimming not to mention that the 3.75" backspacing will put unwanted stress on your front end. i would suggest sticking to a wheel with no less than 4.5" of backspace but even with a 15x7 with 4.5"BS youll have to trim to fit 30's. if you do not want to trim find a rim with stock specs(15x7 6"BS) your only other option to avoid trimming would be a lift.
i have the same wheels on mine. you will need 4.5 back spacing. With 30's they might rub a little in the front. Also just to let you know. You dont get the center caps that is shows. You get chrome ones. they dont even make the black ones
Originally Posted by NVANZEE
(Post 233453)
Originally Posted by mikeinwi
(Post 233452)
there is no such adapter out there to change BS from 3.75" to 4.5". there is another member on this site(wolfpack) with 3.5-4" of lift running 265/70/15's(roughly 30") on a rim with 4.5"BS and he had to do some light trimming, so if you run a 30"tire with a 3.75"BS rim with no lift youll be doing moderate to heavy trimming of you fender and front valance.
i got em from the same place. i just looked and i guess they dont have them. Mine are 8in wide instead of 7
(Post 233458)
(Post 233457)
you should be fine with the stock tire size.
(Post 233463)
its best to post questions/problems on the forum so a number of people can use the information and thanks for the compliment, but beleive me there are plenty of other members around who know much much more than i do.
if you do go with that back spacing you will go through hubs more often due to the added pressure
(Post 233466)
i would go with the 5"BS for the reasons NVANZEE stated, but without rubbing the stock tire size will be the biggest.
(Post 233467)
the farthe the wheel sticks out the more stress there is on the wheel hubs. In result making them heat up more than normal. So they go bad quicker than with a stock set up
If anyone has seen them let me know please :)
Im looking for black steel crawler rims
For my 2003, chevy blazer im looking for rims similar or the same as these http://hazmatoffroad.com/store/image...rawler_152.jpg Specs that need to match these to fit... 5 on 4.75 bolt pattern 15" rim 6" backspacing if possible... |
