will these fit?
Old Aug 10, 2007 | 07:43 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
Default will these fit?
will these bf goodrich mud terrains fit on my 97 blazer 4 door 4X4?
31-1050R-15/C1 RWL
if not, what do i need to do to make them fit?
Old Aug 10, 2007 | 08:06 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: will these fit?
Yes they should fit on the stock rims at stock 4x4 height as long as your rear suspension is not sagging any. What I mean by this is that the front leaf spring mount should have the leaves coming out towards the rear flat not below the mount point. Some others have pics of this. Hope this helps
Old Aug 10, 2007 | 11:34 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
its not so much the rear suspension to worry about.... with a 97 model, your front suspension has probably started to sag..... 31's will have a clearance issue at stock height... especially with a mud terrain... popular consensus is that a torsion bar tweak will eliminate most of the rubbing.... but you will rub 31x10.50x15's at stock height....
Old Aug 11, 2007 | 03:25 AM
Yeah, I blanked out when I replyed before I was thinking of 30x9.5's those should work on stock height and with a little tweaking as stated above, you should be able to fit 31's.
Old Aug 11, 2007 | 10:30 AM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
yea they should be fine, but if not get out the sawzall and a cutting torch
Old Aug 11, 2007 | 10:56 AM
thanks guys, this is my DD so will the torsion bar tweak effect anything? and how much would i tweak it?
Old Aug 11, 2007 | 12:59 PM
drperry's Avatar
If you're going to crank the TB, do it until you clear the tires by enough that they won't rub when you're beatin' on it...
You will have increased wear on things like balljoints, cv-axles, and pretty much every other front end component, other than the diff... Steering might be good to go, but not sure
Old Aug 12, 2007 | 09:35 AM
tommyd's Avatar
tommyd is an unknown quantity at this point
Just get 30's if its a DD Gas Milage on these tires sucks. I have the 30's and average 15-16 and about 12-13 in the city. I was getting 22 average before I added the tires. Look in my gallery you can see pics of the 30's on my truck
Old Aug 12, 2007 | 07:18 PM
thanks man, i'll look around to see whati can find you know anywhere i can get them for relativley cheap?
xJakeLIKEShisBLAZERx
Tires and Wheels
Sep 10, 2011 12:50 PM
blazer123456789
Tires and Wheels
Aug 22, 2007 07:30 AM
JST4SHO
Tires and Wheels
Apr 13, 2007 10:26 AM
flowmasta
Tires and Wheels
Aug 10, 2006 11:58 AM
ivannj
Jan 21, 2006 09:52 PM
