ZQ8 wheels with a2002 Jimmy???
Old Jan 10, 2008 | 12:38 AM
Logan's Avatar
Logan is on a distinguished road
Default ZQ8 wheels with a2002 Jimmy???
On my 02 Jimmy, I want to get the ZQ8 rims with some bigger BFG All Terrains. I got a set of Xenon fenderflairs. I saw a ZR2 today with the steelie 2wd rims, and it made me think of getting the ZQ8 rims. I do plan on doing offroading with it as well. I looked, but cant really find much info. Might be because im tired and usless online, but any help would be greatly appreciated!!!!
Old Jan 10, 2008 | 08:11 AM
Default RE: ZQ8 wheels with a2002 Jimmy???
What have you done to your truck? Generally, swapping over to 2wd rims will cause problems with clearance when making tight turns...
Old Jan 10, 2008 | 09:51 AM
Logan's Avatar
Truck is stock. The Blazer I saw was stock ride hight too. Planning on a 5" lift in spring or summer.
Old Jan 10, 2008 | 09:53 AM
Comparing a stock ZR2 to a stock Jimmy is apples and oranges. ZR2's are lifted from the factory. You could always try, but without some kind of a lift, you will mostlikely have problems.
Old Jan 10, 2008 | 10:05 AM
Logan's Avatar
Is there a way to take the ZR2 suspension and put it on a reg. 2dr? Priced out a 5" lift, $2300 + tax. I really like the look or the zq8 wheels, so id like to make them fit.
Old Jan 10, 2008 | 10:09 AM
Logan's Avatar
So this is what a 5" lift will look like on my jimmy I take it
https://blazerforum.com/albumtn.aspx...t105804353.jpg
cant get the pic to show up 4 some reason.
Old Jan 10, 2008 | 10:20 AM
The ZR2 option includes a completely different frame. You should be able to use 2wd rims with a body lift and a simple t-bar crank. Search around a bit because I know this has been discussed before.
Old Jan 10, 2008 | 10:25 AM
Logan's Avatar
Ive been looking, but I really suck at searching. I can never find What im looking for. Now I have to find a company that makes lift kits for the non ZR2.
Old Jan 10, 2008 | 04:19 PM
WolfPack's Avatar
Superlift (6') and Trailmaster (5'). Type 'lift' in the search bar.
Old Jan 10, 2008 | 06:44 PM
Logan's Avatar
Lookin at superlift. I can get the 6"for 2600, and the 2" for 800. I might just do 2". I still have 2 kids to take in and out daily.
