Zr2 and lift kits
Old Aug 23, 2010 | 09:34 PM
AJBert's Avatar
this is true. and Did they make any zr2 pickups with just the single cabs? or the ones that I saw are they just look alikes?
If I'm not mistaken, single cab ZR2's were made up until '98. After that, they were all extended cabs.
And, yes, I can look at a Blazer, Jimmy, S-10 or Sonoma and be able to tell you if it is a ZR2 or a clone. Really not hard to tell the difference.
Old Aug 23, 2010 | 09:48 PM
Benedict1337's Avatar
hmmm I'm still confused about the single cabs since they had the 98+ headlights. Both I see are red with black flares so are they clones? I would think i'd be fairly easy to put zr2 flares and 31's on a single cab
Old Aug 23, 2010 | 10:02 PM
zedartwo's Avatar
You would need the whole fender, Or do a hack job to put the flares on. Could just be converted front ends?
Old Aug 24, 2010 | 12:59 AM
old skool luvr's Avatar
Originally Posted by NVANZEE
like zedartwo said. you cant make a standard blazer a ZR2. They have different frames, suspension, fenders, and rear quarters. For lifting it do a search. There is a whole list of options for you. There is not a 4in lift. You can do a 2in bodylift and crank the tbars 1.5in and put shackles in the back.
guys, don't be giving misinformation.
they don't have different frames, just front suspension & mounting points (don't be starting that debate again! it was like 3 or 4 pages llast time)
and besides the debate about making a "cloned" ZR, where are you gonna find the flares? i've only ever come across one complete set of them, and i was nice enough to steer a fellow member to them.
@ the OP; if you wanna go big, you're gonna have to be prepared to pay a bit.
Old Aug 24, 2010 | 01:08 AM
RangerG's Avatar
Not to mention the ZR2 flares won't fit on a regular S-series. Bushwackers are your only option and they will be from $400 to beyond, unless you wanna do a lot of hacking.
Leaf spring hangers are an easy way to tell a ZR2 from a non-zr.
Old Aug 24, 2010 | 09:30 AM
AJBert's Avatar
I went and checked and I know a guy that has a '99 regular cab ZR2, so I stand corrected on them ending in '98.
Very easy way to tell if it is a ZR2 or not on someone's ride that you just happen to see is to look up in the front wheel wells. ZR2 will be stamped in there. Along with a number of other ways to tell.
But, reg cab ZR2's do indeed exist.
Old Aug 24, 2010 | 11:01 AM
NVANZEE's Avatar
yeah, most of the mounting points a different. Since they are welded to the frame I considered it to be part of the frame. Its not like you could replace a non-z frame with a z frame without cutting the brackets off and welding new ones on.
Old Aug 24, 2010 | 10:59 PM
fair enough.
but what's stopping me from finding a ZR roll-over (i've come across 2 actually), buying, stripping off the damaged body, and dropping on a "normal" Blazer body?
hell, i'll even stretch it a bit, and slip it under my 4 door!
wouldn't be the first time i stretched a truck.
03blazertucker
Lifting Tech
Feb 10, 2010 07:24 PM
tcd1388
Mar 21, 2007 07:07 AM
jessesjimmy
Suspension Tech
Jan 27, 2007 01:17 AM
97blz4x4
Suspension Tech
Nov 14, 2006 01:21 PM
mikehillis1@yahoo.co
Suspension Tech
Sep 19, 2006 12:28 PM
