TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
will not shift
Old Feb 15, 2010 | 07:23 PM
bulldog's Avatar
bulldog is on a distinguished road
Default will not shift
I have a 2005 trailblazer and it will not shift out of second gear any help would be appreciated
Old Feb 15, 2010 | 09:22 PM
awe341's Avatar
awe341 is on a distinguished road
Usually when this happens it means that your computer has detected some kind of problem with the transmission or transmission control system. It will go into limp mode and stay in second gear in order to let you get it somewhere safely while trying to protect itself from further damage.
You are going to need to get it taken in and hooked up to a scanner capable of checking transmission codes if you want to find out exactly what is wrong with it. It could be something simple like a bad sensor that can easily be replaced or it could be something internal that is wrong. Getting any stored codes will go a long way to finding the problem.
Old Feb 16, 2010 | 07:12 AM
Does your speedo work properly? If it won't shift out of 1st gear, it is usually a VSS (vehicle speed sensor) problem.
*Moving to the GMT360/370 Tech section*
Digitized
Jan 12, 2014 12:07 PM
ffalan
Aug 1, 2010 10:49 AM
JohnnyChevelle
Feb 2, 2010 11:33 PM
riggermm
Nov 4, 2009 06:06 PM
Blahman20
Nov 3, 2008 09:45 PM
