Looking for a nut kit
So, I am at my wits end. In the process of changing out the spider injection and the nut kit. I was able to order the spider injectors, however the nut kit is almost impossible to track down.
I live in Canada, and when I think I have found one, they don't deliver to Canada. WTF?
if anyone on here has some insight as to where I can find a nut kit, it would be most helpful.
Thank You
wtdfxup
Thank You
wtdfxup
They're actually not bolts or nuts at all.
Don't know why it's called a nut kit.
But, they are actually fuel injector fuel lines. They are the two hoses that connect to the spider injectors inside the intake plenum.
Thanks,
As far as sourcing replacements, have you tried a GM dealer? What local parts suppliers have you gone to that cannot source it?
it's a 1995 Chevy Blazer LT 4 DOOR
4.3L, V6 engine code W
These lines do NOT like to be disturbed once they have been installed. As such, I would not recommend used getting used ones. I have seen lines less than 6 months old leak after being removed due to other issues and that was with someone being careful. They are fragile, fickle things.
Have tried Canadian Tire, NAPA,Partsource, Piston Ring.....none have stock anywhere in Canada.
Online, I have tried Rock Auto, Parts Avatar, AutoPartsWay, all out of stock and don't expect stock for 3-4 months.
Amazon.ca....out of stock
Amazon.com...has stock, but don't ship to
Canada. Which normally, isn't a problem, I'm an hours drive to the border, but with not being able to cross the border, I can't go pick it up.
Damn!!
