Website Problems and Suggestions Need help using the website? Ask here. Have a suggestion to make us better? Tell us here.
Looking for a nut kit
Old May 11, 2021 | 10:01 AM
wtdfxup's Avatar
wtdfxup is on a distinguished road
Default Looking for a nut kit
So, I am at my wits end. In the process of changing out the spider injection and the nut kit. I was able to order the spider injectors, however the nut kit is almost impossible to track down.
I live in Canada, and when I think I have found one, they don't deliver to Canada. WTF?
if anyone on here has some insight as to where I can find a nut kit, it would be most helpful.
Thank You
wtdfxup
Old May 11, 2021 | 10:18 AM
What nut/bolts are you looking to replace. I just had my engine rebuilt not long ago, and had to order a bunch of parts from different dealers/sites.
I'm in ontario
Old May 11, 2021 | 10:47 AM
wtdfxup's Avatar
I'm in ontario
Hi Don,
They're actually not bolts or nuts at all.
Don't know why it's called a nut kit.
But, they are actually fuel injector fuel lines. They are the two hoses that connect to the spider injectors inside the intake plenum.
Thanks,
Old May 11, 2021 | 10:52 AM
wtdfxup's Avatar
I'm in ontario
This is what the lines look like.
https://www.dormanproducts.com/p-3431-55163.aspx
Old May 11, 2021 | 11:37 AM
If your looking for the lines, you might find some good ones at a scrap yard. But you don't say what year and model you got. The lines you posted don't look familiar to me...
Old May 11, 2021 | 12:42 PM
These lines do NOT like to be disturbed once they have been installed. As such, I would not recommend used getting used ones. I have seen lines less than 6 months old leak after being removed due to other issues and that was with someone being careful. They are fragile, fickle things.
As far as sourcing replacements, have you tried a GM dealer? What local parts suppliers have you gone to that cannot source it?
Old May 11, 2021 | 03:01 PM
wtdfxup's Avatar
Doh!!! Yeah, year and info would help.
it's a 1995 Chevy Blazer LT 4 DOOR
​​​​4.3L, V6 engine code W
Old May 11, 2021 | 03:15 PM
wtdfxup's Avatar
So, yes. I have tried multiple local GM dealers, and their systems all show the lines as being "discontinued". The fellow told me that once a part is discontinued, they have no way of sourcing a replacement. No dealer in Canada has them.
Have tried Canadian Tire, NAPA,Partsource, Piston Ring.....none have stock anywhere in Canada.
Online, I have tried Rock Auto, Parts Avatar, AutoPartsWay, all out of stock and don't expect stock for 3-4 months.
Amazon.ca....out of stock
Amazon.com...has stock, but don't ship to
Canada. Which normally, isn't a problem, I'm an hours drive to the border, but with not being able to cross the border, I can't go pick it up.
Damn!!
Old May 11, 2021 | 05:38 PM
I see what you mean now. A lot of online retailers are showing it as out of stock.
My local NAPA can have it to me tomorrow (PN: NOE 7002370), but that doesn't help you any.
Old May 11, 2021 | 08:03 PM
wtdfxup's Avatar
Yep!! However, that PN, is one I haven't seen. May give NAPA a call tomorrow, and try that PN. See what they say.....worth a shot. 😁
