4WD Posi-Lock Link System
Old 01-04-2009, 10:40 AM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default 4WD Posi-Lock Link System
Balkamp Part Number 7354012 Napa is much cheaper than Name Brand (Posi-LoK) if anyone is interested.
Example JC Whitney Name brand $300.00
Napa $127.00
This system replaces Vacuum switch, lines and Actuator.
Old 01-04-2009, 11:13 AM
Blazin_Jason's Avatar
Default RE: 4WD Posi-Lock Link System
Anymore info on it? Is it the same install as the posi lok? I need to get a self locking cable setup for my blazer.
Old 01-04-2009, 12:52 PM
neo71665's Avatar
Deff need more info, pics are also nice
Old 01-04-2009, 01:17 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Definitely interested in this myself.
Old 01-04-2009, 02:44 PM
neo71665's Avatar
I found this ya'll
http://www.napaonline.com/NOLPPSE/(S(ieibzj55keoudx55w511mb55))/Detail.aspx?R=BK_7354012_0179775797
Four Wheel Drive Posi-Lock Link System
Front[/align] Part: BK7354012 Product Line: Balkamp
This part can only be purchased from your local NAPA Auto Parts store.
Attributes Additional Parts Required:No - Everything Is Included w/ Package
Contents:Set Collar, Cowl Grommet, 7" Tie Strap, Vacuum Cap, Cable Spring, Bolt-Pack, Dash Bracket 1988-94, Dash Bracket 1994 & Up, Lever, Support Plate, & Wave Washer
Product Application:System Takes Off Vacuum That Connects 2 Axles Together, Uses Cable Assembly to Make 4-Wheel Drive
Warranty Limited Lifetime Material Safety Data Sheet (MSDS) There is no MSDS for this item
Old 01-04-2009, 06:23 PM
rdhack's Avatar
Yep that's it. That is the same pic as the original pos-lok by the way.
Old 01-05-2009, 06:22 PM
I can't get the links to work or pulled up with the part number. Have you used this before or seen one in person? I'm mostly concered on how it installed. The new posi loks install directly to the diff is what I want.
Old 01-05-2009, 07:13 PM
SockJock's Avatar
Try typing in "4x4 Posi-lock" in their parts search. That's what I had to do and it worked for me.
Old 01-05-2009, 08:16 PM
neo71665's Avatar
Also interested if its the like the 2nd design or first design. It was icing over down here today but if its clear tomorrow I'm going to napa and picking one up (or at least ordering one).
Old 01-05-2009, 09:08 PM
ORIGINAL: neo71665
That would be sweet. I'm very interested in this if it is a newer design.
Quick Reply: 4WD Posi-Lock Link System
