87 chevy ghost problem
Old 03-14-2016, 12:56 PM
khart83's Avatar
khart83 is on a distinguished road
Default 87 chevy ghost problem
My name is Kevin, I don't have a blazer, but I have a 1987 chevy silverado, 350 fuel injection, it also has a high performance chip in it. I have come across a problem where the truck will randomly cut off, as if I turn the key. It doesn't matter hot or cold, when I go to crank it back up, the engine cranks and will eventually fire, then cut right back off. Once the engine finally starts it runs as if it is getting too much fuel, and black smoke comes out the tailpipes. If hold the throttle down it clears up and will run fine until the next time it cuts off. The truck also has dual tanks. I have replaced: Distributor, plugs, plug wires, coil, computer, fuel filter, fuel pump relay, coolant sensor, both oil sending units, idle air control valve, map sensor, throttle position sensor, egr valve, egr solenoid, the throttle body has been rebuilt, o2 sensor,switching valve on the dash, put on new grounds and replaced other grounds. This has become very frustrating, I have taken it to multiple repair shops and they tell me they can't fix it or don't even want to look at it. I need help here!! Thanks!
Old 04-12-2016, 02:00 PM
ShotCaller's Avatar
ShotCaller is on a distinguished road
I had a similar problem. It was the ignition control module under the cap. Did you replace it when you changed your distributor or re-use the old one?
did you ever find out what is was?
ghost
The Chop Shop
13
06-18-2009 09:37 PM
omalley576
06-12-2007 04:52 PM
minijosh
10-17-2006 04:20 PM
tpdavis
08-10-2006 03:16 PM
Quick Reply: 87 chevy ghost problem
