93 s10 blazaer stalling again after doing rebuild
Old 06-10-2014, 01:42 PM
boscoedoodle's Avatar
boscoedoodle is on a distinguished road
Replaced the rotor and distributor in my 93 w code and set the time. The dist had a lot of crud in it and a lot of button wear. Runs much better
  #42
Old 10-04-2014, 11:01 PM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default Replaced ECU.
Replaced ECU like 3 months ago. No sign of strange power issue. Knock on wood so far.
TTFN,
Josh
  #43
Old 11-25-2015, 06:46 PM
Johnny Danger's Avatar
Johnny Danger is on a distinguished road
Default STUMPED. runs good but.....
Facts: Runs good at idle and under cruise conditions like under 45 maybe 50. Sputters at high rpm. partial throttle responds with bogging. stab it to the floor and it will go better but not perfect. code 42 showed up on scanner. replace spark module, and ignition coil. ran OHMS test on Pick Up coil. Same problem exists. Fuel pressure is up at 60psi key on, 56 at idle, and 55 at approx 1800 rpm. Any ideas where I need to check?
  #44
Old 11-25-2015, 08:48 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
This thread is over a year old, Please start a new thread so we can help you. Thank you.
chevyracingfan23
14
06-19-2012 02:32 PM
dylan71
04-25-2011 08:39 AM
gatelocked
02-28-2011 04:52 PM
KRUSHER
01-02-2010 07:25 PM
c.andrew
10-28-2009 01:28 AM
Quick Reply: 93 s10 blazaer stalling again after doing rebuild
