94 4wd switch ?
Old 01-02-2010, 12:07 PM
jimschevey's Avatar
jimschevey is on a distinguished road
Default 94 4wd switch ?
I have searched throughout the forum. My 4 hi light is not coming on. I have 4 lo and 2wd. I am going to start with the switch co i went to advance, autozone and napa and they can not find the 2 button switch before 95. If anyone has replaced theirs is it possible to give me a part number and manufacturer. Thank You. I bought this 94 chevy blazer yesterday. it has the 4.3, automatic tranny. 2 button switch (4 hi & 4 lo)
Old 01-09-2010, 04:13 PM
jimschevey's Avatar
I just replaced the switch that goes on the dash. That was not the fix. i just ordered the switch that goes to the transfer case. I replaced all the vacuum lines. I can not find another fuse box under the hood so the one in the cab must be it.
Old 01-14-2010, 11:15 PM
UnknownFish's Avatar
UnknownFish is on a distinguished road
I had this same issue, I replaced the vacume switch on th transfer case, indicator light switch on front axle, 2 button switch on dash, and still didnt work, then I replaced the actuator under the battery, that didnt do it, went back over the vacume lines and found the vacume gang thingy(dont know technical name)was cracked, replaced that and have 4 hi and 4 lo and 2, if after you replace the switch on transfer case if that doesnt do it, it could be the encoder motor on the transfer case or the tccm under the dash, good luck.
Old 01-15-2010, 08:24 AM
jimschevey's Avatar
Thank you, now that it is 40 degrees it will be a lot more tolerable to go looking for the problem. i will go looking for the vacuum thing you were talking about
88Chevy
06-21-2012 11:53 AM
madmack4
05-24-2012 12:59 PM
BearingEater
06-17-2011 03:16 PM
cide
11-08-2010 08:17 PM
JediKnight2
09-11-2008 07:58 PM
Quick Reply: 94 4wd switch ?
