ABS light on, how to fix? 1991 4x4
Old 03-07-2008, 08:57 PM
tim_dean's Avatar
tim_dean is an unknown quantity at this point
Default ABS light on, how to fix? 1991 4x4
Hello, my ABS light is on (1991 s10 4x4 TBI, 4 door). I reset the ABS circuit/codes using a jumper wire, but it comes right back on as soon as it is powered up/started. Does this mean its the EBCM? Or is the BCM part of the engine ECM? Where do I go from here??
Thanks
Old 03-09-2008, 11:04 AM
jamon8 is an unknown quantity at this point
Default RE: ABS light on, how to fix? 1991 4x4
I want to know how to use the jumper wire and reset the abs
my light is on and I would like some info also
Old 03-19-2008, 05:09 PM
tim_dean's Avatar
Anybody? Can someone tell me where the ABS brain (BCM?) is located at?
Old 03-19-2008, 06:07 PM
The ABS control module should be located on the side of the ABS unit itself.
What codes came up? Might point to what is wrong... Just a thought...
Old 03-20-2008, 07:36 AM
how do you check abs codes
Old 03-20-2008, 08:42 AM
rdhack's Avatar
rdhack is an unknown quantity at this point
I bought a code checker for 29.99 and determined why my light was on. It was a faulty front wheel sensor. Usually there is a problem when that light stays on. While I still had normal brake operation I did not have 4WAL until I replaced the sensor. I suggest you figure out the problem - fix it - then reset the light to off.Or if you are happy with regular brakes just unplug the light.
I cannot remember where I purchased the code reader from but I simply did a google search and found one. They are complete with instructions and the list of problems for each code and are really easy to use. I thought it much better than connecting the terminals with jumper wires.
Old 03-20-2008, 08:44 AM
rdhack's Avatar
Oh the brain plugin is below the steering column between your legs.
Bertbart
06-16-2012 04:53 PM
Tinted
03-15-2012 02:56 PM
95redblazer
03-08-2011 01:30 PM
jlucey2
10-23-2010 12:37 PM
Dodge Guy
10-25-2006 08:48 AM
Quick Reply: ABS light on, how to fix? 1991 4x4
