brake Booster question
Old 07-20-2014, 08:06 PM
Davidisme's Avatar
Davidisme is on a distinguished road
Default brake Booster question
I have a question removing the booster seems pretty basic but how do I remove the push rod from the pedal.
Thanks for the help.
David
1994 s-10 blazer
Old 07-21-2014, 08:17 PM
Davidisme's Avatar
I see a small cotter pin where the two connect I assume I am supposed to pull that and it will free up the pushrod. tight quarters that's why Im wondering. Thanks
Old 07-21-2014, 08:27 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Correct!
Old 07-21-2014, 08:39 PM
Davidisme's Avatar
thank You, now I know Im on the right track.
Old 07-24-2014, 08:17 PM
Davidisme's Avatar
Default What the flip????
Ok, am I missing something here???? All four bolts on the inside of the cab have been removed I have the push rod off the brake pedal, the two bolts on the booster itself have been removed WHY wont the booster come loose? I have tried pulling it pushing it, love tapping it from the inside of the cab or the back side of the booster, this beast will not budge, am I missing something???? What a PITA.
On the other side of the coin people complain about the upper left bolt in the cab....I used two extensions and a swivel adapter and I was able to get it no problem....of course after getting frustrated over LOL
David
Old 07-24-2014, 08:45 PM
odat's Avatar
odat is on a distinguished road
just a thot - sometimes during assembely inside the cab there are little paper thin flat washers that thread on the studs to hold everything in place untill nuts are installed
Old 07-26-2014, 02:24 AM
Davidisme's Avatar
ok, thanks bud. tomorrow, it comes out!!!
Old 07-26-2014, 04:09 PM
Davidisme's Avatar
Ok, booster is out new one is in place waiting to be secured in with bolts. Looking at the pedal and this is where I knew I would run into trouble. Can someone give me some direction with how this plate goes back into place. I know that the white and red button have to touch as is evedent by the contact points on the plate, but I cant get it to line up correctly without depressing the white button I believe it is.
Thanks David
Attached Thumbnails brake Booster question-brake-pedal-1.jpg   brake Booster question-brake-pedal-2.jpg
Old 07-26-2014, 09:02 PM
rexazz2's Avatar
if I am seeing right the plate in place should hold down both buttons
The buttons are normally held down until you press the the pedal
Old 07-27-2014, 01:27 AM
odat's Avatar
if i remember right the top hole in the plate goes over the booster rod on the rod pin and the second hole is bolted to the brake pedal - plate lines up to depress both switches at once - one is brake light and the other maybe the cruse control cancel switch
K1500brute
03-14-2012 04:04 PM
whistle
11-20-2006 12:42 PM
consernedguy
11-06-2006 11:19 PM
JCG1
Suspension Tech
09-19-2006 02:07 PM
khalid_20879
01-03-2006 01:00 PM
Quick Reply: brake Booster question
