hey guys im new to the forum and i need your help
Old 11-18-2008, 10:44 PM
hdelgad1's Avatar
hdelgad1 is an unknown quantity at this point
Default hey guys im new to the forum and i need your help
i live in slc i have a 91 blazer 4.3, anyways in june it stoped working and i replaced the fuel pump because it was bad, but since then it did not want to start anymore, i checked the fuel and it goes up all the way to the carb but it des not go through the carb so i checked the injectors and they were not clogged, now i'm stumped and don'tknow what to do any idead of what it could be?
thanks for listening.
Old 11-19-2008, 05:48 AM
rx7_guy is an unknown quantity at this point
Default RE: hey guys im new to the forum and i need your help
ignition control module...u'll need a obd scanner to find out
Old 11-19-2008, 07:00 AM
I assume we are talking about a TBI motor here. Am I correct?
If so, then I would start by verifying that you are getting the proper fuel pressure to the throttle body. You say that you have verified that you have fuel to the throttle body, but the presence of fuel and appropriate fuel pressure are not one in the same.
While someone is attempting to start the motor, can you see fuel spraying out of the injectors?
arob5848
08-12-2011 03:54 PM
incrediblehulk
Tires and Wheels
04-17-2011 09:56 PM
tred2587
02-20-2009 08:52 PM
travisrussell88
09-13-2008 08:50 PM
Quick Reply: hey guys im new to the forum and i need your help
